Am I ageing WW2 vehicles too much?
  • GerryW
    • Feb 2021
    • 1757
    Ok, so I might be opening a can of worms here, but it's crossed my mind when attacking/weathering kits.
    Given that WW2 lasted roughly 6 years, in that time a lot of innovation/r&d/upgrades took place, plus attrition on the battlefield/air strikes/partisan activities, just how long would a vehicle last?
    Next question, how rusty and worn would that vehicle be after being used and abused for 12 months?
    Why am I putting faded paint effects and rusty metal on a sub 52 week old vehicle? :thinking:
  • AlanG
    • 6296
    Having read about the battles in Normandy, i'd be surprised if a tank there lasted more than 5 weeks. Dirty yes. Rusty...not so sure.
    • GerryW
      • Feb 2021
      • 1757
      That's the sort of thing - I've spent a good few (enjoyable) hours getting the effect of faded paint and rusty metal. Just sat here drinking coffee this morning, and it's suddenly dawned on me just how much of that wasn't needed.:tongue-out3:
        • 18882
        Depends upon the environment too Gerry. Desert areas are very harsh on paint finishes, temperate zones much less so. Not only that, armour plate etc is a very different thing to sheet mild steel, so doesn’t rust as readily. I think contemporary farm vehicles would suffer similar weathering, apart from obvious battle damage, so should be a good touch stone for ideas.
        • David Lovell
          • 2186
          Gerry weathering has become somewhat of a art form there are some eye blistering models being built a walk around the tables at shows is mind boggling wether realistic or not being your question ,I guess in the majority of cases not but its all in the eye of the beholder, its your model you do what you want and feel is correct in your own eyes no one will tell you that what you've done is wrong there are no rules you should be doing this for your own pleasure.
          I find things like rear decking with enough stowage to fill a lorry ,covering air vents and filters ,even worse denying 360 rotation of the weapon, vehicles driven into courtyards to take a bit of time out and a brew ok but driving in is a massive no no but I wouldn't care about how weathered it was I think now we all look and accept the picture being presented. My biggest thing is why does it seem every model built has a bloody bucket hung on the back.
          Please Gerry do what you want do it for yourself worrying about other people's compared to your own is the quickest way to fall out of love with this fabulous pass time. Dave
            If realism is the goal, then most AFV kits get far too much chipped paint and rust added to them by modellers — and possibly not enough dust, dirt and fuel stains. A derelict tank that’s been standing in a field in western Europe for a couple of years since the war, sure, that would have rust on a lot of parts that aren’t armour steel or welds (welding rods were usually stainless steel in the 1940s). One that was still in use would not have much, or any, rust on it: the crew would be performing regular maintenance on it and pretty quickly get rid of rust (or at least paint over it). Same with any chipped paint.
            As Tim says, in the desert it’s a very different matter. I’ve read that the bottoms of tanks in Egypt and Libya would often be nothing but bare steel because of the scouring action of the sand, and certainly the tracks would be after any amount of driving through it (whereas in the mornings, after having been parked overnight, tracks often had a very thin layer of rust on them, caused by dew). Faded paint would also be far more common in a desert environment than in western Europe.
            Whereas dust and dirt build up very quickly on operations, and crews would not be cleaning their vehicles to parade-ground condition after operations, especially if the weather was going to be bad anyway. Spilled fuel is another thing that leaves noticeable stains, and for much longer than dirt. Russian tanks were probably the worst in this, there are photos where it looks like the crew poured more fuel next to the filler cap than into it … American tanks also frequently have noticeable spilled fuel down their sides. I suppose German tanks would have few stains, as due to their general fuel shortage I would expect German crews to try and minimise waste.
            • The Smythe Meister
              • Jan 2019
              • 6248
              To quote a Famous Punk Band...........
              "Oh you silly thing,you`ve really gone and done it now".............
              :tears-of-joy::tears-of-joy::tears-of-joy:
              • AlanG
                • 6296
Name:	Can of worms.jpg
                • outrunner
                  • Apr 2019
                  • 2420
                  I only use light weathering now and again on a few models basically because I am not very good at it and it is so easy to go over the top. Most of my models are just left with the basic paint job, let's face it, they were all brand new from the factory initially. :smiling5:
                  Andy.
                  • GerryW
                    • Feb 2021
                    • 1757
                    Yes Tim, I've read that desert sand will act like sand paper/a grit blaster, though not done any desert models for years. Sort of tempted now though.
                    Dave, think that loading something up to the gunnels depends on how it's going to be presented - behind the lines, maybe but covering vents/cooling grills I'd like to think that I'd notice - must admit that I enjoy working with rust and faded paint effects, so might still do it.
                    Sort of take your choice of 'realism' and 'enjoyment'. Possibly the wrong phrase.
                    Staining by fuel is a 'nasty', and that's one of my 'goals' - getting the dirt/fuel mix running down from the filler cap, one of these days I might be able to do it!
                    Andy.
                    Andy, is a good thought, and it's going to have been issued to someone as a new vehicle :thumb2: :smiling5:
                    • AlanG
                      • 6296
                      Hence why sand is sometimes used as a medium for shot blasting paint removal. It's very good at the job
                      • JR
                        • May 2015
                        • 18273
                        Gerry.
                        As said its in the eye of the beholder, manufactures are having a field day selling us all sorts of brews to achieve the " look."
                        To me its part of the fun of modelling, you want to make it your own, oh and plenty of mud !
                          Gerry,
                          I'm pretty much in the dirt first school, rusting might occur on small items, like shovels, buckets etc, but main bodywork, no ( unless maybe a crumpled fender ). What always amazes me is the amount of excess baggage that was roped & strapped on in any convenient space - all open to weather and dirt! Mud & general grime are the first priority.
                          • eddiesolo
                            • Jul 2013
                            • 11193
                            First off: Armoured vehicles tended to have a much thicker paint coat and despite crew climbing all over, dragging shells up etc they only got slightly marked. Of course more damage occured when hitting hard items, tress, buildings etc.
                            Softskins tended to be mild steel construction so damage was more.
                            You have to think of the vehicle you are working on and weak points: fenders, guards etc, items lower down on the chassis and hull. Bolt areas, stowage box hinges would all be prone to wear and rust.
                            The overall finish would fade with weather, rain, wind, sand, sun. 90% of these vehicles once they left the factory lived outside.
                            Now, they wouldn't be rust buckets, commanders or maintenance staff would repaint and replace broken items if they could. A tank is no good if parts seize or rust solid.
                              • 18882
                              Some great responses here :thumb2: My pet hate is things that are chipped to death..it’s rare to see chipping in pictures, but sometimes every model tank looks like it’s been attacked by the enemy armed with chipping hammers…..
