Hand holds foot rungs..
  • Caustik Filth
    • Jan 2022
    • 364
    • Rob
    • Portsmouth
    I've seen a Trumpeter wire bending jig set for knocking up hand holds for turret sides etc.. would anyone recommend such a tool or would anyone have a d.i.y. method for making many uniform pieces as I is struggling with me pliers and fingers! Cheers Rob
    • 18890
    There’s a bit of a discussion on this subject in this thread Rob….
    • Caustik Filth
      • Jan 2022
      • 364
      • Rob
      • Portsmouth
      Ta v.much Tim I'll ave a butchers after work ...tea break over!
        • 15653
        Hi Rob
        In the thread Tim linked too I don't think the jig was well thought of. I seem to remember it was too flimsy for copper wire.
        I use serrated tipped pliers. The jaws are tapered so different sizes of handle can be made. Just mark the groove corresponding to the size you want and you can make as many as you need all the same.
        • minitnkr
          Charter Rabble member
          • 7517
          • Dayton, OH USA
          I use the Jim method also. You can use smooth jawed pliers to flatten the attachment areas for riveted/screwed or bolted grabs/steps.
          • rtfoe
            • 9072
            I always prefer flat nosed pliers and anyway I'm not making a factory amount of turrets that need grab handles.:smiling2:
            • Caustik Filth
              • Jan 2022
              • 364
              • Rob
              • Portsmouth
              Originally posted by Jim R
              Hi Rob
              Cheers Jim,
              New pair of pliers for me me thinks!
              Great tip, 2 pair of pliers then I reckon groovy and flat ! Thanks..
              True Richard
              I'm not going into production but for me next job I think I'll need a few!
              Thanks
                Rob,
                what size are you looking for? I have seen metal staples ( from an office stapler ) used as rungs on the side of a concrete strongpoint. It depends on what sizes are available!
                • Caustik Filth
                  • Jan 2022
                  • 364
                  • Rob
                  • Portsmouth
                  Rob,
                  Nice one Dave
                  That's a good idea and the odds and sod draw in kitchen might just contain said items !
                    Tim is referring to the bit that starts here with David Lovell’s mention of them and continues in following posts. TL;DR version: they work, kind of, but not as well as you would probably like them to.
                    I was meaning to modify one to see if that helps, but have completely forgotten to actually do that …
                    • Caustik Filth
                      • Jan 2022
                      • 364
                      • Rob
                      • Portsmouth
                      Ta Jakko I'll check that out just now..
                      • Caustik Filth
                        • Jan 2022
                        • 364
                        • Rob
                        • Portsmouth
                        Cheers Jakko saved me a few mins there and I will go for pliers, all part of the joy, experiment and suck it and see tanks
