Info needed.... M.2 (Ma Deuce) .50 Cal Machine gun
  • langy71
    • 1947
    • Chris
    • Nottingham
    Gents does anybody know if the carrying handle on the .50 cal machine gun normally rests downwards or upwards,
    I'm working my way through the Meng Magach m6 and the 'ranging gun' above the main gun seems to have the handle pointing / resting 'upwards' and other images I've found seem to have it hanging below the barrel..
    is the handle loose so it will rest in any position it's left in ?
    pics for reference.
    thx for any info
  • Allen Dewire
    • 4741
    • Allen
    • Bamberg
    Evening Chris,
    The handle for the barrel was loosely attached to it. It was used to hold the old barrel as you would unscrew it from the .50 cal. when you wanted to change it for another. If it was hot, you had an asbestos glove to do the change. Again, the same for screwing the new barrel into the MG. It would normally hang down as the wire loops weren't tight around the barrel. Changed enough of them in my day. HTHs...
    Allen
    • minitnkr
      Charter Rabble member
      • 7519
      • Dayton, OH USA
      Amen.
      • Airborne01
        • Mar 2021
        • 3954
        • Steve
        • Essex
        Evening Chris,
        Allen
        Amen to that Allen!
        • langy71
          • 1947
          • Chris
          • Nottingham
          Evening Chris,
          Allen
          Thanks Allen,
          So, basing my build on that information I've got a bit of 'scratchery' to rectify the 'wrong' image Meng have used...
          • langy71
            • 1947
            • Chris
            • Nottingham
            I'm also guessing that it was 'remotely fired' using some kind of solenoid system,
            (given it's position, I'm guessing you wouldn't want to be climbing out of the turret to use it, as it also appears to be in a fixed 'ranging' set-up.)
              • Allen Dewire
                • 4741
                • Allen
                • Bamberg
                Sorry Chris,
                I can't help you with the Israeli usage on their tanks or how they were controlled. I used to stand behind mine in the cupola of my M113. Holding on to the grips tightly saved me from being thrown out of the cupola a few times though............
                Allen
                • minitnkr
                  • 7519
                  • Dayton, OH USA
                  Ranging/solenoid are correct.
                  • langy71
                    • 1947
                    • Chris
                    • Nottingham
                    Originally posted by Jakko
                    Brilliant video @Jakko good to see it going full auto at the end,
                    although it does seem to be a bit of a faff to set it up .. you certainly wouldn't' want to have to change the barrel when the 'sh%t is getting real'
                    thx mate
                    • langy71
                      • 1947
                      • Chris
                      • Nottingham
                      thx buddy
                        That’s why the modern versions have a quick-change barrel, which, incidentally, the Americans were pretty slow to adopt.
                        • rtfoe
                          • 9073
                          I have a question...how much constant firing before you need to change the barrel after it gets too hot?
                            I tried finding that by looking at some manuals online, but they don’t appear to say. The point of the heavy barrel (the gun discussed here is the M2 HB variant) was to have it absorb more heat so it wouldn’t overheat as rapidly as the previous types with a lighter barrel, while avoiding the water cooling that another variant had, so I guess this succeeded?
                            • Mini Me
                              • Jun 2018
                              • 10711
                              All this depends on several factors........all the gunner needs to know is....when your shots start to wander off target you have lost your dope due to core shift in the barrel metal (caused by hi temp).........time to change the barrel. If that is not possible, fight on and try to compensate for the shift in accuracy....not always consistent.
