Run paint
    Run paint
    Don’t worry if you’re spraying camouflage on your model tank and the paint runs:
    [ATTACH]461828[/ATTACH]
    (Via Bas Slaats on the TWENOT forums.)
    I kind of wonder how many points you’d lose in a competition if you entered a model of this exact tank without supplying this photo with it, though.
  • Steven000
    • Aug 2018
    • 2826
    • Steven
    • Belgium
    Nice picture,
    Originally posted by Jakko
    ...I kind of wonder how many points you’d lose in a competition if you entered a model of this exact tank without supplying this photo with it, though...
    Well I don't know but the paint-runs are really small on a 1/35 scale model, so a certain skill is needed to make it look realistic
    • adt70hk
      • Sep 2019
      • 10402
      I just love these sorts of shots. Proves beyond all doubt that it was far from perfect in the field.
      • The Smythe Meister
        • Jan 2019
        • 6248
        Ah..... That's my tank builds off the hook then!!
          • 15670
          Now all I want, Jakko, is for you to find a reference photo with gluey finger marks and all will be well.
          • KarlW
            • Jul 2020
            • 1522
            And road wheels weren't masked in real life either, overspray happens, scaled down overspray is difficult though.
              • Jan 2019
              • 6248
              Not for me it ain't Karl......
              .... I can get it EVERYWHERE !!
              • Mini Me
                • Jun 2018
                • 10711
                [ATTACH=CONFIG]n[/ATTACH]
                The judges would probably knock you down if you didn't get the "runs" in the right place!! :tongue-out3:
                  • 18893
                  Tools weren’t always removed either, as I understand it Karl, but I don’t think I’ve ever seen that modelled.
                    TBH, I don’t think you’d want to paint a model of this tank using actual paint runs — I would try it by spraying it without those, and then adding the run paint with a fine brush.
                    I have, and I would do it again if I were to build a model of a WWII German vehicle in camouflage pattern But most modellers seem ignorant about the colours of tools anyway, painting them all in wood and bare steel when certainly American ones were dip-painted olive drab at the tool factory. Not sure about other nationalities, but chances are several did it in a similar way.
                    Something I just noticed in the photo is the “shadow” of light paint to the top left of several of the rivets, especially to the left of the door and above the chap sitting on the jerrycan. Somebody sprayed the dark patches there from the right and below, rather than straight on.
                    BTW, another thing to note (that I did spot immediately) is that the rims of the roadwheels have had all the paint worn off them where they rub against the track teeth. This was very common on all American vehicles with this kind of suspension/track (so M2, M3, M5 light tanks, M2, M3, M4 mediums, and all their variants), and not just in desert sand like here, but is very rarely modelled because it’s often not obvious in photographs.
                    • Steven000
                      • Aug 2018
                      • 2826
                      • Steven
                      • Belgium
                      TBH, I don’t think you’d want to paint a model of this tank using actual paint runs — I would try it by spraying it without those, and then adding the run paint with a fine brush...
                      Yes that's what I meant ; )
                      • JR
                        • May 2015
                        • 18273
                        Arh, paint hurling, yes that's an interesting photo, showing camo in the field . Considering a lot of camo was applied by the crew in the field using a general purpose spray gun and probably paint thinned with some unknown thinners it's not surprising they ended up with over spray etc . Rather different to wingy things that must have been sprayed with a much greater amount of care .Still there was a war on so no time for cutting back , dusting off and playing around like we do !
                        • stona
                          • Jul 2008
                          • 9889
                          Runs are really hard to scale - like water
                          Overspray is easy enough, just don't overdo it!
                          • Gern
                            • 9212
                            Oh Gods! So now that's three colours I'll have to mask to get accurate tank wheels! :sad:
                              • 18893
                              Rub marks are relatively easy Dave. Just rub the edge of an HB pencil lead along the wear point…..instant worn steel effect! You can have a fun hour or so colouring in track edges and sprocket rims etc….
