question: Worn steel road wheels
    Hi! My first time here and of course ive got a question. I have Bin researching into my next build, an italeri elefant 211 (wich is an awsome tank) and while i was looking around i saw an old build of the same tank made by this guy Ferdinand by Chris Leeman (Italeri 1/35) wich is breathtaking. And my question is how do one paint those worn steel road wheels? He unfortunately doesn't go into detail about this effect which has bin logged in my brain ever sins.
    When I've done steel roadwheels on a Tiger or Panther, I've painted them as usual & then run a pencil around the rim and the rims edge to simulate worn shiny metal. It works a treat!
    Patrick
      Originally posted by \
      When I've done steel roadwheels on a Tiger or Panther, I've painted them as usual & then run a pencil around the rim and the rims edge to simulate worn shiny metal. It works a treat!Cheers
      Patrick
      Wow! That was quick thanks Patrick! one more question how do i get the browish shade
        Having just looked at the link to Chris's Ferdinand / Elephant, I see he does his roadwheels like me!
        For painting them, I'd use desert yellow, a dark brown oil or enamel wash & drybrush with either buff or lightened desert yellow.
          A million thanks Patrick! This build is gonna be sweet.
          • geegad
            • Mar 2010
            • 2329
            Question have you got an airbrush or do you use the brush..???
              i use the brush so its not going to be the same but i have to try it out
                Many thin coats if you're using a brush Tobias. Give it a go & keep us informed of your progress. I've always had a hankering to do an Elefant in the Italian campaign.
                Patrick
                  Same here, with acrylics, and am pretty pleased with the results so far.
                  Like Patrick said - thin coats and build it up slowly. You can blend colours by adding a thin coat of a new colour to a partly dried previous colour. Its possible to wash colours together with a wet brush before they completely dry (preferably natural hair as nylon can sometimes scratch the paint rather than wash it over)
                  And finally Parick - an Italian campaign Elefant ..... i'm up for that too, maybe we could have a twin build (not a build off coz i'm not exactly in your league matey )
                    Same here, with acrylics, and am pretty pleased with the results so far.Like Patrick said - thin coats and build it up slowly. You can blend colours by adding a thin coat of a new colour to a partly dried previous colour. Its possible to wash colours together with a wet brush before they completely dry (preferably natural hair as nylon can sometimes scratch the paint rather than wash it over)
                    I wouldn't put it like that Colin! Your work is pretty damn good! I'd be up for a twin build, just as soon as I've got the others out of the way.
                    Patrick
                      Many thin coats if you're using a brush Tobias. Give it a go & keep us informed of your progress. I've always had a hankering to do an Elefant in the Italian campaign.Cheers
                      Patrick
                      I will cheers! Im going to make a diorama with this tank at the battle of krusk.
                        Thanks for the advice! keep em comin =P
                          I wouldn't do that! At Kursk they were Ferdinand's ( named after Ferdinand Porsche ) but due to the lack of a bow mounted MG, they suffered high losses from Soviet infantry.
                          After Kursk they were fitted with a bow MG & applique armour & renamed Elefants by Hitler himself!
                          Patrick
                            Ok then, a future 1/35 Elephant Italian campaign spec twin build it is!!!
                            Sorry to hi-jack the thread Tobias
                              I wouldn't do that! At Kursk they were Ferdinand's ( named after Ferdinand Porsche ) but due to the lack of a bow mounted MG, they suffered high losses from Soviet infantry.After Kursk they were fitted with a bow MG & applique armour & renamed Elefants by Hitler himself!
                              Patrick
                              Whoops! I got my history all wrong =/ im always in a rush
