1/35 Rope and straps
  • A_J_Rimmer
    • May 2024
    • 800
    • Arnold
    • North Wales
    Hi All,
    How do you guys emulate things like rope in 1/35? I'm thinking of stowage tie-downs and tow ropes etc.?
    I think I get how to make straps, maybe using metal foil, but ropes escape me.
    Cheers!
    Arnold Judas Rimmer BSc SSc
    ''Happiness is a Triple Fried Egg Sandwich with Chilli Sauce and Chutney''
  • AlanG
    • 6296
    Last bit of 1/35 rope i made, i used a thread off my pair of jeans. It had the strands and was easy to make it hold it's shape because it soaked up dilute pva nicely
      Ropes? Use cotton thread - paint it with diluted PVA to reduce the 'hairiness' - button thread for heavier ropes. The twisted wire for hanging painting/photos is useful, as well as stripped thin electrical wire. Thicker wire for towing cables. Loads of household stuff can be utilised. The thicker foil from takeaway cartons, or pies can represent thick leather, or canvas, just a matter of looking at things with a modelmakers eye!
      • wasdale32
        • 1113
        • Mark
        If you have any old usb cables you could try stripping off the insulation and pull out the wires. You should be left with the woven sheath which can be twisted to make tow cables. Copper will be softer and more malleable than brass. Old coax tv leads are good for heavier cables
        • Waspie
          • Mar 2023
          • 3488
          • Doug
          • Fraggle Rock
          USB wire was what I used for a tow cable on a AFV.
            • 18868
            For hemp ropes I use ezeline if it needs to be taut or waxed thread if it doesn’t. Wire ropes I use brass picture hanging wire, sometimes just a couple of strands rewound using a bench vice and a pin vice (one to hold and one to twist). Straps I use pewter or heavy foil cut to size with a scalpel.
              • 15595
              Strips of masking tape doubled over, sticky to sticky side, can make good straps. Thin wire can be used to make buckles.
              • A_J_Rimmer
                • May 2024
                • 800
                • Arnold
                • North Wales
                All very imaginative suggestions Gents - thanks, it's appreciated. I'll raid my bits tin and see what I've got.
                Thanks muchly :thumb2: :thumb2: :thumb2:
                • AlanG
                  • 6296
                  Straps can also be made from lead wire rolled flat. And because it's lead it makes it well easy to mold around things
                  • A_J_Rimmer
                    • May 2024
                    • 800
                    • Arnold
                    • North Wales
                    Cool idea, I do have some of that.
                    • rtfoe
                      • 9060
                      Some good tips from the guys. In the past I used just strips of type writing paper for straps. Now it's either thicker grammage paper or thick foil from the IKEA Salmon paste tube. For rope I use different gauge fuse wire but if you want it to have the twined look then twisted hand phone charging wire works for me.
                      Wabble
                      • A_J_Rimmer
                        • May 2024
                        • 800
                        • Arnold
                        • North Wales
                        Wabble
                        Don't have a lot of Salmon paste tubes, but I do have a lot of saved wine bottle foil - thanks for the tips!
                        • dave
                          • Nov 2012
                          • 1827
                          • Brussels
                          For straps I use »lead » foil off the top of wine bottles flattened out and cut. With fusewire to Make fittings.
                          • A_J_Rimmer
                            • May 2024
                            • 800
                            • Arnold
                            • North Wales
                            Thanks Dave! AND you get to drink the wine!
                            • wasdale32
                              • 1113
                              • Mark
                              Another useful material is self adhesive aluminium plumbing tape. It can be easily embossed for webbing and being self adhesive will easily wrap around stowage etc. I even use it to simulate zimmerit as it can easily be removed if the effect isn't what you want and it is much closer to the correct scale thickness. You can also use it for natural metal finishes on aircraft.
