Vickers E Mk B Light Tank, 1/35, MirageHobby
  • PaulTRose
    • Jun 2013
    • 6483
    • Tattooine
    so since the Porsche is temporarily on the back burner til I can lay my hands on some paint I thought I would start this as I want to try a few things and don't want to do it to an expensive kit
    Vickers E mk B light tank by Mirage Hobby who are a Polish company ive never tried before....picked the kit up at a show for a whopping 4 quid! so I don't mind if it all goes a bit Pete Tong...the guy had quite a few different ones all at the same price, wish i had got more now
    http://en.wikipedia.org/wiki/Vickers_6-Ton
    I'm actually quite impressed with the quality....not quite Tamiya but comparable to Italerai or best that Revell can do
    not sure what scheme I'm going to do.....the two schemes on the instructions are both Polish Army from mid to late 1930's....one is a very difficult one similar to WW2 Japanese type......the other is very similar to late WW2 German tri-colour, which I might do just for the practice, but it might also just go a dark green
    since it dosnt come with any figures i might include one out of this lot, will decide when the time comes
    Per Ardua
    Seems a nice kit!
    There are some interesting products by unknown brands...O_o
      • 22771
      It does look a good kit Paul I will stick around to watch this one
      • monica
        • Oct 2013
        • 15169
        looks good to me, and i like it also o_O
        will keep an eye on it
        • PaulTRose
          • Jun 2013
          • 6483
          • Tattooine
          this is turning out to be a great little kit!
          filled up the interior with some big nuts to add some mass to the whole thing, also added a small nut under all that central plasticine with a hole in the bottom of the hull so i can use some thread rod as a handle
          ive put together Thomasz the Tank Commander
          the kit comes with a modification the Poles did to their tanks,...they found the engines overheated due to lack of airflow so they made some ducting to force air into the engine compartment
          Per Ardua
            That looks great Paul!
            • PaulTRose
              • Jun 2013
              • 6483
              • Tattooine
              so its pretty much together, primed and ready for painting
              must admit it, Thomasz is an ugly bugger lol
              i was toying with doing a three colour camo scheme but ive settled on just a plain green one
              two reasons really, one is this was only ever meant to be a test mule to try a chipping/weathering technique ive never done before so i dont want to over complicate things
              the second is, since its just going to be a plain colour i thought id try practicing pre-shading, its something ive never really got to work, mainly cos i think im too heavy handed
              Per Ardua
              • flyjoe180
                • Jan 2012
                • 12424
                • Joe
                • Earth
                Good progress Paul, it's looking tidy.
                • PaulTRose
                  • Jun 2013
                  • 6483
                  • Tattooine
                  i hope this is going to work lol
                  stage one of this process is to make what is essentially a enamel paint using matt enamel varnish, enamel thinners and rust pigments
                  it helps apparently to have different shades of rust
                  and it dosnt need to be too neat
                  this will now get a day or so to dry.....cant do anything til saturday afternoon anyway thanks to work getting in the way, i also need enough time to airbrush the three different colours for the camo in one day
                  im going back to the 3-colour camo as i dont think im going to be able to do the preshading as it will mess up the chipping/rusting technique so i may as well ahve a go at the camo as i do have the three shades needed
                  Per Ardua
                  • PaulTRose
                    • Jun 2013
                    • 6483
                    • Tattooine
                    im dying to get on with this, things keep getting in the way....like work!
                    but ive done the adding the latex with a bit of a sponge........might get to put on the base coat of yellow tomorrow, and the brown and green on monday.....then the fun really begins
                    Per Ardua
                      Looking great.
                        It's true!! The best part is now
                        Looking very good!
                        • Peej
                          • Aug 2014
                          • 919
                          You've only just started it and it's driving you NUTS! Seriously I'm going to follow this as I'm starting to get interested in Tanks and figures. Good luck with the build.
                          • Richi72
                            • Sep 2013
                            • 1100
                            Hi Paul, interesting technique you are using did read about it, but having some pics definitely better.
                            Will keep a close eye on this.
                            Cheers Richi
                            • PaulTRose
                              • Jun 2013
                              • 6483
                              • Tattooine
                              managed to get the camo on today
                              the instructions show either a Japanese style patchwork camo which looks incredibly difficult or a tri colour stripey one, which i have had a crack at
                              going to leave it til tomorrow to really dry before piggling off the Maskol
                              colours are a little bright at the moment but some wash and some matt varnish should tone it all down a bit
                              Per Ardua
