Pzkpfw 1 Ausf C
  • aaron
    • Oct 2011
    • 2019
    #46
    Thanks Tommy and Monica.
    Monica some equipment is just a dry fit because I'd never reach all the tools when detail painting so I get what your saying.
    • flyjoe180
      • Jan 2012
      • 12476
      • Joe
      • Earth
      #47
      Looks good so far Aaron. Lots of fiddly bits but coming along well.
      • aaron
        • Oct 2011
        • 2019
        #48
        Thanks Joe, you're right about the fiddly bits.
        • aaron
          • Oct 2011
          • 2019
          #49
          So the turret is pretty much built.
          [ATTACH]99783.IPB[/ATTACH]
          [ATTACH]99784.IPB[/ATTACH]
          Then there is this gap, the fit of this kit is beautiful so I don't think it's a fit issue. There are only 4 pics I can find on the Web of this afv and none have a clear shot of this. I dont know weather to fill the gap or not.It is on both sides and I'm scratching my head over this.[ATTACH]99785.IPB[/ATTACH]
            My solution is to run a little glue into the gap to fill it slightly then paint it as a panel line.
            scott
            • aaron
              • Oct 2011
              • 2019
              #51
              Yep, I didn't know if it was supposed to be there or not. I'll just fill it. Thanks Scott.
                It looks almost too regular to be a gap Aaron - are you sure that it's not a place for something to fit in there?
                If not, I'd fill it.
                • aaron
                  • Oct 2011
                  • 2019
                  #53
                  I was hoping you would drop by Patrick, it really does seem like it is supposed to be there.
                  [ATTACH]99816.IPB[/ATTACH]
                  This is the only pic in the destructions showing the angle.
                    Having Googled the kit, I found this image - not sure, but possibly the guy filled it in the same place?
                    [ATTACH]99817.IPB[/ATTACH]
                    If not, there's definitely nothing in that spot.
                    • aaron
                      • Oct 2011
                      • 2019
                      #55
                      Yessir that is the spot. I'll fill too, thanks Patrick.
                      • monica
                        • Oct 2013
                        • 15169
                        #56
                        maybe just an over site with the mold for it,?
                        I think if Patrick says it ok i would mostly be so,
                        found this may put your mind at rest,dose not seam to have any think in that spot,
                        think what im going off is a little different in model,but much the same
                        http://www.primeportal.net/tanks/olav_bellman/panzer_ii_ausf_c/
                        [ATTACH]99831.IPB[/ATTACH]
                        [ATTACH]99832.IPB[/ATTACH]
                        [ATTACH]99833.IPB[/ATTACH]
                        [ATTACH]99834.IPB[/ATTACH]
                        • aaron
                          • Oct 2011
                          • 2019
                          #57
                          Thanks Monica,I had made the comparison between the two c turret and they are very similar. I plan on adding some more weld seams like the two has.
                          • aaron
                            • Oct 2011
                            • 2019
                            #58
                            Box art weld lines.
                            [ATTACH]100039.IPB[/ATTACH]
                            My attempt.
                            [ATTACH]100040.IPB[/ATTACH]
                            [ATTACH]100041.IPB[/ATTACH]
                            [ATTACH]100042.IPB[/ATTACH]
                            Ready for primer.
                            • monica
                              • Oct 2013
                              • 15169
                              #59
                              very nice how did you do the weld,line look spot on,
                              • flyjoe180
                                • Jan 2012
                                • 12476
                                • Joe
                                • Earth
                                #60
                                Nailed it I reckon. Nice addition Aaron. This is really inspiring, I;m going to crack out my Tiger tank soon and have a go.
