As I have issues with this model I thought I might as well give you a build sequence just in case anyone has this model and has the same problems so the initial model is very good sensible sprue connections reasonable fit not as good as a Tamiya but still reasonable and in some cases they’ve used the key system where they’ve use one part has one type of locking key as the other part has a slightly different one so that was good to see
However now we come to the elephant in the room so speak and that’s the tracks. I can see what Amusing we’re trying to do but from what I can tell it’s not going to work. These are the so-called clip together tracks where you have two little pins either side which are supposed to clip into each other the only trouble is once you get a significant length of track about 20 links when you click the top one in the middle of the track will probably come unclipped forcing you to re-clip it again and then again and again and again sorry Amusing this system does not work. The only way this would work is if you put a pin all the way through from one side to the other so there was nothing to unclip as such these tracks will be glued to the wheels similar to the Tamiya way of doing it and then individual links around the idler and sprocket that’s the only way I can see this working unless someone else has got a better idea and I don’t mean going going and purchasing an aftermarket add-on
I’ve added four pictures as that seem to be the amount that we can add hopefully illustrate the problem as always thank you for your comments and I’ll update you with the next section which should be the attachment of the top of the hull and remaining side skirts Once we got the tracks sorted out, which I think is gonna be a right pain as you can see from the last picture, they’ve all felt to pieces again
Regards
Colin
Regards
Colin
