Chieftain Mk 10 Berlin Camouflage 1/35 Meng
  • Bigfoot57
    • Jun 2015
    • 1101
ID:	1237906 Click image for larger version
ID:	1237904 Click image for larger version
ID:	1237905 Click image for larger version
ID:	1237903 so here’s my next project in the continuing saga of British tanks from 1944 through to the modern day this time from the 1960’s to the 80s with the Chieftain and the height of the Cold War were envisaged tank battles in cities hence the colouration of this one then the general colour of the German house namely brick red white and grey. The idea of being that the tank would back itself into a wrecked building. All the stuff would collapse on top of it and it would merge into the background happily this did not happen as in WW II
    Anyway the kit itself appears to be very good. The plastic is superior quality and when parts are cut off from the sprue there is very little cleanup to be done. I have already constructed the running gear namely the suspension units which have real springs in them the idler the sprockets and the road wheels which again have polycaps inside them please see the attached photos for a description of how they were built next will be a paint cleanup of the wheels and then we move onto the lower hull
  • scottie3158
    • 14202
    • Holbeach
    Chair pulled up. Spent a few happy hours working on the turrets of these.
      • 22770
      Great start, looking forward to more updates.
      • Richard48
        • 1897
        • Richard
        • Clacton on Sea
        Im in as well.Love Chieftains.
        • Bigfoot57
          • Jun 2015
          • 1101
ID:	1238664 Click image for larger version
ID:	1238663 Click image for larger version
ID:	1238662 Click image for larger version
ID:	1238661 Well sorry it’s taken so long to actually reply back but I’ve been learning how to paint straight lines on curved surfaces which is not the easiest things to do anyway here is the turret with its main colours now blocked and there’s obviously more detail to be added to the turret such as machine guns etc and the ammunition boxes and the baskets, but the main turret colours are now done all I Gotta do now is transpose those down to the side of the tank and onto the skirts, but I wanted the turret done 1st so I had a reference point with which to work to
          • Bigfoot57
            • Jun 2015
            • 1101
ID:	1238669 Click image for larger version
ID:	1238668 Click image for larger version
ID:	1238667 Click image for larger version
ID:	1238666 Turret Construction again, very good fit Apart from the search light box and the toolbox both these had large gaps for some reason which I had to fill with filler sand smooth and paint over other than that everything else fitted perfectly most of it clipped together
            • scottie3158
              • 14202
              • Holbeach
              Superb mate
              • Andy T
                • Apr 2021
                • 3239
                That's some great paintwork!
                  • 22770
                  Coming along very nicely, nice painting.
                  • Bigfoot57
                    • Jun 2015
                    • 1101
ID:	1239379 Click image for larger version
ID:	1239380 Click image for larger version
ID:	1239381 Click image for larger version
ID:	1239378 Right since my last posting I’ve been painting the main hull of the tank finally got to finish which I’m happy with so all that’s left to do now is the side skirts the tracks which obviously you’ve got to be done before the side skirts go on well, you should be able to clip the side skirts on so we’ll see then there’s just little final details such as a machine gun on the top of the turret and final painting details such as indicator lights and things fire extinguishers, etc
                      • 15707
                      Now that's what I call an eye catching paint job. Well done. Until your first post explanation I didn't know why that camo was used
                      • scottie3158
                        • 14202
                        • Holbeach
                        Very nicely done.
                        • Steven000
                          • Aug 2018
                          • 2829
                          • Steven
                          • Belgium
                          Nice progress, paintwork looks great ?
                          • Bigfoot57
                            • Jun 2015
                            • 1101
                            Quick update on the Chieftain now moved onto painting the skirts it should be the final paint required along with track construction which in my opinion is absolutely hideous. Let me explain the jig that they use is brilliant. Can’t fault it. The only problem is after putting the pins in using the insertion tool that they come on the tracks are so tightly packed into the jig that when you lift them up it frequently bust the pins and so the track links start falling to pieces as you can see I’ve deviated into using .6 mm brass rod in places I wish I had more of it I would have used it all the way through but I can only use it in. Should we say high stress areas in my opinion? There are only two types of track that I can work with that’s the rubber ones which everybody hates but at least you can sew them together at the top and hide them behind the skirt usually or you fork out for metal ones all the other methods I’ve seen of constructing tracks have problems with pins or the track fall to pieces after it’s been pinned together the only other one I seen that actually worked was from Tamiya on the Comet where you build the tracks in a straight line on the bottom and top and you just join it around the idler wheels and the sprockets incidentally if you want a kit that goes together like that 1/32 scale Spitfire then this tank will be for you. The Comet is absolutely faultless construction wise instruction wise the perfect kitClick image for larger version
                            • scottie3158
                              • 14202
                              • Holbeach
                              The tracks as you say all have their ups and downs and I have used nearly all types. The build is looking great.
