Chieftain Mk 10 Berlin Camouflage 1/35 Meng
  • Bigfoot57
    • Jun 2015
    • 1101
    #16
ID:	1239870 Right hand side of the tank is nearly done little bit of paint touchup to do but overall the camouflage has come out pretty good just need the track painting and adding to the side then I can move onto the left-hand side
    • Bigfoot57
      • Jun 2015
      • 1101
      #17
ID:	1240201 Click image for larger version
ID:	1240200 Click image for larger version  Name:	IMG_2143.jpg Views:	0 Size:	392.0 KB ID:	1240202 Click image for larger version  Name:	IMG_2144.jpg Views:	0 Size:	275.9 KB ID:	1240199 Camouflage finally finished just a case now of adding the machine gun the wing mirrors, two aerials and I think that will do it so the next time you see this after these pictures it will be in the Finished Armoured section
      Overall this kit was very good excellent fit apart from what I pointed out earlier which was the search light housing and the toolbox. They seem to have a problem so I had to fill the gap with the filler next up was the PE. The PE was awful. It would not glue no matter how many times I etched it eventually got it to stick but the baskets lived up to their name. They were right baskets to do and then we come to the tracks well the idea behind the tracks was brilliant conception using the jig. They snapped together really easy the pins pushed into place but the tracks were held so tightly in the jig that when you pulled the track out of the jig it snapped the pins off there by allowing the to tracks fall apart again luckily, most of them are hidden by the skirts and you’ve only got just a little bit at the front and back showing
      • Richard48
        • 1892
        • Richard
        • Clacton on Sea
        #18
        Fantastic camo.I saw a few Chieftain kits for sale at Telford.Tempted but have to disciplined.Far too many kits already.
        • Steven000
          • Aug 2018
          • 2826
          • Steven
          • Belgium
          #19
          Nice finish Bigfoot, not a camo-scheme you see every day on the forum, well done ?
          • Graeme C.
            • 1597
            • Graeme
            • UK
            #20
            The Chieftain certainly looks good in Berlin camouflage, pity about the tracks.
            • Bigfoot57
              • Jun 2015
              • 1101
              #21
ID:	1240592 Click image for larger version  Name:	IMG_2187.jpg Views:	0 Size:	198.8 KB ID:	1240589 Click image for larger version  Name:	IMG_2188.jpg Views:	0 Size:	201.1 KB ID:	1240590 Well its finished sorted out the tracks and the wing mirrors hope I’ve done you Chieftain supporters justice in my efforts on this build
              Here’s what I liked & disliked and there’s a decal mistake on behalf of Meng as well
              So I liked the following instructions clear and precise along with colour call outs when needed the type of plastic minimal clean up required the fit of the parts most are keyed si they only fit one way the track construction jig
              Dislikes Tracks too tight on jig after the plastic pins have been inserted most snap off due to the force required to remove them from the jig in a lot of places i used.6mm brass rod
              The PE despite etching was reluctant to stick with any sort of CA glue the Turret Baskets in particular were a right pia
              Decals one was printed totally wrong see if you can spot it Click image for larger version  Name:	IMG_2186.jpg Views:	0 Size:	188.0 KB ID:	1240588
              • Bigfoot57
                • Jun 2015
                • 1101
                #22
ID:	1240596 Next build in the ongoing British Main Battle Tanks 1944 to present day will be the Chieftains successor the Challenger 1 Mk3 in Desert Storm colours which is mainly sand yellow so nice and simple paint scheme this time
                • HAWKERHUNTER
                  • Feb 2012
                  • 1565
                  • Steve
                  • Halifax, West Yorks.
                  #23
                  A really interesting camo. Looks really good.
                  • scottie3158
                    • 14201
                    • Holbeach
                    #24
                    That is a cracking result. Thanks for the post script on your thoughts.
                    • Richard48
                      • 1892
                      • Richard
                      • Clacton on Sea
                      #25
                      Turned out lovely.Shame the kit was troublesome.The post script was welcome as ive always wanted to do a Chieftain.For my standards i think Tamiyas Golden oldie is suited to me with a bit of tinkering.
                      Great choice on Chally 1,I wish some company would make a real good kit of one.I know there are aftermarket stuff from Scorpion models but end up costing fortune to do kit justice.I like the Chally 1 in green in service in 1980s.Think i have some QDG markings somewhere.
                      Chair pulled up for this dude.
                      • Bigfoot57
                        • Jun 2015
                        • 1101
                        #26
                        Richard also in line for being made is a Challenger 2 Desertised a Challenger 2 with TES probably do that in European / Nato camo and when it comes out, I’ll be doing a Challenger 3 assuming somebody produces one if not then a scratch built add on’s could probably be produced the main change is the Leopard 2 A7 gun be adopted in place of the current rifled one this will allow the Challenger to use Nato ammo including the smart munitions in development and the fitting of the Israeli anti misile system which is already in use on the Merkerva along with uprated engine and suspension
                        Regards
                        Colin
                        • Bigfoot57
                          • Jun 2015
                          • 1101
                          #27
                          For the decal mistake if you look at the two yellow and white chevrons on the back of the tank the one on the left has yellow in the corners and the middle stripe the one on the right has white in the corners and a middle stripe so one of them is wrong and I suspect the one on the left is correct and the one on the right been printed back to front from the looks of it
                          • Airborne01
                            • Mar 2021
                            • 3963
                            • Steve
                            • Essex
                            #28
                            Love Chiefies and I love your rendition! Very nice mate
