Tamiya's M1A1 Abrams 120mm Gun MBT
  • Adrian "Marvel" Reynolds
    • Apr 2012
    • 3008
    After seeing a History channel programme on the Battle of 73 Easting, I just had to build this awesome bit of kit. Seems last year I built mainly SciFi, this year I'm build conventional kits
    I'm building this straight out of the box as a learning project ready to do my M3A3 Bradley later on.
    [ATTACH]107152.IPB[/ATTACH]
    Having done so research and speaking to the armour builders in our club I decided to add the non slip surfaces, there are plenty of ways to do this with PVA and sand etc but thought I would try the texture paint from B&Q that a member told me about.
    [ATTACH]107153.IPB[/ATTACH]
    I used masking tape and Maskol to mask the top turret after a successful trial on some plastic card, I'm pretty happy with the results.
    [ATTACH]107154.IPB[/ATTACH]
    As I have a few long term projects on the go this one will be a slow build but hopefully I'll learn a lot as I go.
    Comments welcomed as always
    Adrian
  • monica
    • Oct 2013
    • 15169
    have seen that stuff about before ,the textured surface ,but never seen it used ,dose look good to me,
      looks like one for the memory banks. wonder what will get pushed out this time? maybe the other half's birthday
        First at all...nice choice Adrian!
        I'm fascinate, this new tip is simply genial. The result looks very good
        Thanks to share it
          That looks good to me might use this on mine.
          scott
          • Steve Brodie
            • Sep 2014
            • 4652
            I have heard of that before but never seen it used, looks excellent. Nice one
              • 22771
              A very nice start Adrian and a great tip with the paint. I will pinch that idea
                Nice , I like the textured paint idea too , how fine is the texture Adrian .
                Richy
                  • Apr 2012
                  • 3008
                  Thanks all, Richard, it's a very fine mix, I've found its best to apply one thin coat then another once its dry. It appears thick when you apply it but shrinks right back to a great effect.
                  Adrian
                  • Lee W
                    • Feb 2014
                    • 4654
                    • Lee
                    • Sherborne
                    Hmmm think this could interesting!
                    Lee
                    • takeslousyphotos
                      • Apr 2013
                      • 3900
                      That looks good Adrian ............ I've got half a tin of that in the garage. I used it on an uplighter. Now I know what to use the rest on. Valspar also do a Matt Coat which I use it gives a first class finish and none of that "white speckle" stuff going on.
                        • Apr 2012
                        • 3008
                        Progress on my build, took about 2 hours to mask the main body but the texture paint works really good if your going to use this method I'd recommend that you leave it to dry for a couple of days.
                        Should be adding the wheels tonight after I have undercoated it then I can work on the tracks, luckily they are the rubber one piece ones from Tamiya
                        [ATTACH]108010.IPB[/ATTACH]
                        Comments welcomed as always.
                        Adrian
                          That's looking very nice.
                          Scott
                            That is a cracking idea for the non-slip, Adrian, I will have to look into it. Thanks for the tip. [ATTACH]108014.IPB[/ATTACH]
                              I saw this at B and Q it was selling for £8.30 a can will need to try it on mine when I get around to it.
                              scott
