[ATTACH]115934.IPB[/ATTACH]
After having an unexpected absence from modelling for the last few months I became a bit nostalgic and bought a model truck from a series of kits I remember as 'FROG'.
The model has gone to together very well considering the age of the kit, and all the moving parts work just fine. The parts fit was very good once the flash was removed and the parts tidied up a little with a file. In fact everything lines up perfectly even There were quite a few mould rings to fill but very little filler was used. The build is entirely out of the box except that I drilled out the lights and used some foil for reflectors and acetate to form the lenses. The tiny bits of white are some small blanks of plasticard used to cover mould imperfections rather than use filler.
Not that accurate I suppose and at 1/32nd non standard scale now-a-days but a great modelling experience so far, and it all comes apart.
Model need final painting and all the fiddly bits doing.
Figures are a joke, all are over 6ft tall and skeletal.
[ATTACH]115929.IPB[/ATTACH]
[ATTACH]115928.IPB[/ATTACH]
[ATTACH]115930.IPB[/ATTACH]
[ATTACH]115931.IPB[/ATTACH]
[ATTACH]115932.IPB[/ATTACH]
[ATTACH]115933.IPB[/ATTACH]
