Panzer IV
  • Robert1968
    • Mar 2015
    • 3596
    Panzer IV
    hi chaps
    Well I'm almost finished my WW1 first tank painting exercise so im thinking of my next meaty course. I know this is a popular tank build so I don't think threads on builds will be needed but it's more a new painting exercise for me ( practice )
    My aim is to show a battle tank knocked out so chipping and explosive damage will be my aim damaged areas etc
    I have never built this tank before but looks straight forward ( I hope )
    I'm not too sure on colour ref yet as I want to portray a Afrika korps tank ( Rommels)
    I'm looking for ref on original factory colours ( before sent out to Africa so I can fade the desset colours back to original if that makes sense
    The kit I'll be using is a swapsie I did recently
    Comments and help with ref most appreciated
    Robert
    Looks like a great idea. Can't wait. I like to build my armor based on actual photos.
    • monica
      • Oct 2013
      • 15169
      cool idea like the sounds of it,and yes you did get my attention,
        Robert, Afrika Corps tan was RAL8020 which was adopted in 1942 - a good match for a Panzer IV F1/2.
        Xtracolor do a very good match, X808 but that's the dreaded enamel! Tamiya Desert Yellow is pretty good, but as for Vallejo I have no idea!
        • Robert1968
          • Mar 2015
          • 3596
          Thanks for paint ref guides ( I may go down the line of sparking the tank German light grey for primer ( was it a white interior on Panzer IV?, then a German Wehrmacht blue/ grey then adopt the Africa Korp colours before I wreck it ( so to speak ) I don't want to go down enamel pathway as rather stick to acrylics.
          I've got all the Revell paints / Aqua, I've got al lot of tamiya acrylics ( spares ) and quite a few of Vallejo ( not all ) and a few citadel paints/ life colour but I'm going to have to decide which path on paints to go down as I've had probs with Tamiya and Vallejo not liking each other and making a mess of the builds. I'm trying to aim for light spray painting so not heavy coats. Then after clear coat oils for weathering leaning the end result looking still metal but not heavy coats which then I can add dust and grime too ( mig powders etc)
          As a great wise ( clever clogs said to me keep it simple and then look to weathering it up )
          Who that great modeller was I cant remember off the top of my head?o_O
          Robert
            Robert
            Ha-ha I've no idea who that masked man is! :P
            You're right to go with a German Grey base, off the top of my head I think only the Tunisian Tigers were painted with a sand basecoat from the factory. Everything else was over-painted as & when that unit was sent to North Africa.
            • takeslousyphotos
              • Apr 2013
              • 3900
              Robert
              • takeslousyphotos
                • Apr 2013
                • 3900
                Robert
                Robert...... Tamiya acrylic reacts badly over Vallejo as you've probably found. But Valejo over Tamiya seems to work well..... at least that's what I`'ve found.
                • Robert1968
                  • Mar 2015
                  • 3596
                  I don't think it's the paints that react bad I think it's the liquid they mix the pigments with. I tried once with Vallejo thinners a Copley of drops in the A/b and then added Tamiya paint ( disaster as they don't mix well ) so if I'm using Tamiya paints I use their x20 thinner ( like for like) only problem with that is you really have to clean your A/b thoroughly before using Vallejo paints and their thinners. I tend to use Revell paints and their media but also that works well with distilled water to thin down the paint ( Revell likes Vallejo, I've found but Tamiya is just an oddity.
                  Still I'll not stop using either of the 3
                    Thar's because Tamiya are synthetic acrylics. Although they can be thinned with water, they're actually alcohol based. I thin them with cellulose thinners, something I couldn't do with any other acrylic paint.
                    • takeslousyphotos
                      • Apr 2013
                      • 3900
                      I thin Tamiya paints and clean brushes with IPA... That seems to work..... IPA also strips Tamiya paint a treat if you want to get it off even when it's dried off.
                      • monica
                        • Oct 2013
                        • 15169
                        if using Vallejo,paints for this one,the panzer gray is great,but don't use the German dark yellow,
                        as I find it very much too,green and I use the desert yellow is very good,easy to darken or lighten,
                        and I even use it as my dark yellow in the tri color as well,
                        hope this is of some help,as I just read what Patrick said about the color,so hopped on in,
                        • Robert1968
                          • Mar 2015
                          • 3596
                          With this Panzer build I'm hoping to get 3 crew members that have succumbed to their injuries. Surgery is not my best subject so some advice on dead personnel would be helpful
                          An example of what I'm looking at doing
                          • monica
                            • Oct 2013
                            • 15169
                            that can be a bit of a tricky one,as a lot depends on the figures,
                            I do some from time to time,once you have the figures ,I maybe able
                            to suggest a few things,its fun playing doctor Frankenstein,
                            make V cuts where you need them in the middle of the joints,
                            • Robert1968
                              • Mar 2015
                              • 3596
                              Thanks Monica
                              I'm looking at a few DAK kits ( not too good on flesh yet so the half naked German wil be out but maybe a shirt or two, ( you'll have to give me your top tip on blood too!!
                              Your ever thankful Egor!!!!
