I have done something wrong with the mixture of the airbrush, and can not get the pinture is dry, still sticky ... bright. that is what I hate most in an AFV.
So I decided to clean the kit (damn !!), and paint it again, to see if the paint properly, in texture and appearance is.
But there must be something wrong in my AB, because it keeps happening, bright and pasty finish, not finish drying ...
Even wear perform as expected, i.e. substances ,washed, chipping, not "slip" over the surface, so that the desired effect,is not achieved.
I disassembled the AB, for cleaning "seriously" and when it ride again, back again, clean kit, primer layer and base color, and hopefully that's it.
HI folks, some progress and some new pictures, by the paint looks now, they note, touch as it should be, (thank goodness ..). I have been able to advance basante, because there are some weathering even.
