Miniart 1/35 Mk.III Valentine II
    Hope you don't mind me coming in with a partially built kit with a few pics to show progress to date, there is still a fair way to go.
    This kit was released as a re box with side skirts and a few other parts in 2010 and I purchased the kit from a stall at the Waddington (Lincoln) airshow the same year so it is time it got started. MiniArt kits are a love hate thing with some modellers, I love them. They can be (are, let's be honest) over engineered. Why use two parts when twelve will do? They can also be a bit brittle in the plastic department, though this kit is not to bad in that department. But, enough, let's see the pics.
    The biggest fault with this kit has to be the visible ejector pin marks. I suppose that the ones in the turret and the recoil guard would not be an issue buttoned up. However there is just enough internal detail to tempt you into open hatches so they need to be dealt with.
    First up, the gun
    As you can see, quite a few parts to build a relatively small component. There is a beautifully detailed end cap that is then hidden forever in the mantelet!
    A very nice representation of the radio comes next which sits in the back of the turret once painted up and the photo etch guard is fitted over the front
    Then the complete turret internals. Nothing glued up as the ejector pin marks have to be dealt with
    Before that, I decided to tackle the hull detail. First the drivers station, not massively detailed but enough to see through the hatches.
    Then onto the hull top. It starts like this
    Loads of ejector pin marks that may or may not be visible when completed so got dealt with just in case using super glue and talcum powder.
    Followed by lots of little bits and a few photo etch parts.
    The exhaust is about seven parts and then you put a big cover over it!
    Then, nearly seventy parts, just on the upper hull, later this is where I am now
    Sorry for the long winded introduction
  • takeslousyphotos
    • Apr 2013
    • 3900
    This looks like it'll be a great project to follow Graham.... I`'ll watch your progress.
      Nice start Graham, looking forward to following your build as I have a few of these in the stash.
        I've always fancied a crack at one of these Graham, so I'm watching with interest. The grey plastic reminds me of Dragon kits.
          Defently I will follow this one!
          I love these extended and detailed threads :P
          By the way, excellent start and interesting kit as well.
            This is looking good so far Graham, keep up the good work.
            scott
            • monica
              • Oct 2013
              • 15169
              Nice start Graham,looks an interesting build,i,m in as well,
              • Steve Brodie
                • Sep 2014
                • 4652
                looking good, chair pulled up.
                  Thanks guys. Doubt there will be much done before the silly season kicks in but worry not, there will be more
                    There are quit a few reminders of Dragon kits Patrick. Over engineered and iffy instructions, although instructions are not too bad I suppose. This plastic is also quite like Dragon but some of their kits have very brittle plastic I still use a small razor saw to cut most of the fine parts off the sprue though.
                      I have always loved Valentines, I like to see how it looks, Greetings
                        I think over-engineering is how many manufacturers are going these days Graham - Dragon, Meng, Broncos, Takom... soon we'll need a masters degree from MIT to build a kit!
                        • takeslousyphotos
                          • Apr 2013
                          • 3900
                          Personally......... I find it more challenging.
                            I quite agree Peter! Even if some manufacturers go down the high-engineering route, there's always Academy or older Tamiya kits when we fancy a quick build
                            • tanktrack
                              • Jun 2012
                              • 1429
                              great work so far I have built a number of valentines as British is my thing, can never understand why the have to cover all that nice detail on the exhaust , good luck with the rest of the build .
