just an idea of the finished size, maybe a tad tall?
Trumpeter 1/35 Waffenträger 88mm PAK 43
Ok Graham an honest assessment.
I don't know what the size of the real vehicle would be.
And maybe it is the camera angle playing trick's.
But the building and vehicle look like two completely different scales to me.The doorway looks to be about twice the size of the vehicle.
You know I'm not the type of person to belittle anything and nor am I doing that here..
Here's hoping I am utterly wrong.
Ralph.Comment
all looking so good Graham,I do like your patchy,coating,as they in the right spots,
were you would have darker spots ,so well done on that one,the dark flesh tone,
has worked well over the black as the red/brown,primer,as you also could,use
hull red for that,
I do like the,building,and as for the doorway,with,these,mini art ones,what I,do
is add in a small window,to reduce the high of the doorway down,Comment
Originally posted by \This will be the base for this build. Quite a simple one and mainly OOB with just a bit of rubble scatter. As you can see in the last picture, it sits quite nicely on it and I do like MiniArt buildings to use as a backdrop.
[ATTACH]148483[/ATTACH]
[ATTACH]148484[/ATTACH]
[ATTACH]148485[/ATTACH]
[ATTACH]148486[/ATTACH]
[ATTACH]148487[/ATTACH]
[ATTACH]148488[/ATTACH]
[ATTACH]148489[/ATTACH]
[ATTACH]148490[/ATTACH]Originally posted by \just an idea of the finished size, maybe a tad tall?
[ATTACH]148495[/ATTACH]
The building is going to bring the whole scene to life .
Sorry miss read what Tommy wrote.
Guess I still have a lot to learn haComment
Ralph.Comment
This might help, boys and girl.....
The average external door is 6ft 8" X 2ft 8", so scale that up and you will get the correct door frame size. I agree with our learned members, these Miniart buildings are way too big in scale....
However, I'm sure Graham will make a great job of it - no matter what scale the thing is!Comment
Ralph.
The doorway measures about 70mm which by my reckoning is around 8 feet high so would fit the large door theory on the grander town buildings and don't forget that the Waffenträger is not on its wheels and is a 38t chassis which is surprisingly small. That is why the gun looks so big. I will see what it looks like when it is completedComment
Originally posted by \One of my biggest worries is to spend a lot of time on a model for the scale to be out .
I know I am going make this mistake at some point soon .
It's a bit mind boggling at times for meComment
Originally posted by \You are quite right Ralph. I have said before that MiniArt do way over scale doors and windows. It doesn't help that they use a generic set of doors etc so every building has to have the same over scale doors. I have read on one forum that many of the continental buildings had large doors, larger than British and that is why they do it but I am not sold on that.
And I know you will do a good job of it.
I know everything will looks so much better when paintedComment
Cheers folks. I may..... MAYops: build in a wooden door frame with a panel top and a smaller door will result..... I may not
Anyway, the Waff has it's, hastily applied by the factory to get it out there, camo stripes. Not enough time or paint to do the gun so the keys were handed over to the crew as she is to go stop those pesky Russians.
Next stage will be to detail the gun, not a lot to do there. Then it's gloss coat, varnish, decals, varnish and weathering to blend it all together and soften the contrast. Oh, and those hundreds of indi link tracks
I've just read an article on achtungpanzer stating a waffentrager 88 was used during the battle of Berlin and later taken back to Russia for evaluation fineally ending up in Kubnika museum where its still on display,there's a couple of pictures as well.Comment
Originally posted by \I've just read an article on achtungpanzer stating a waffentrager 88 was used during the battle of Berlin and later taken back to Russia for evaluation fineally ending up in Kubnika museum where its still on display,there's a couple of pictures as well.Comment
