Did a little bit of weathering on the interior, this will have more added when other bits have been fitted. I also got the engine, transmission and air box painted up.
I also painted the inside edge of the rear panel in the exterior colour so I didn't have to try and hand brush it later.
[ATTACH]282781[/ATTACH] [ATTACH]282782[/ATTACH]
And I also built the upper hull interior and got it and it's parts primed.
[ATTACH]282784[/ATTACH] [ATTACH]282785[/ATTACH]
Best of all I found these old scissors in my workshop. They are for cutting lexan body shells (left over from my RC days) and are awesome for cutting sprues.
Great looking work you have done, it really does build into a fantastic model.
I like the fact that all the hatches work so none of your hard work on the interior is lost. I built the same kit last year, there may still be a build log on here some place
It's my first time with individual track links. After 40 my hands started to cramp so I will have to do them in stages. My plan is to do 10 every time I sit at the bench, so should be done fairly quickly.
