Heuschrecke IVb
    Originally posted by Razzie43
    They are two different sprocket wheels,and both i saw them on the B/W pictures.
    Now i'm confused,witch one shall i use?
    Well, they were all prototypes and there are two, or three, variants depending how you look at it, made by Krupp-Gruson and Rheinmetall-Borsig. There's also Sonderkraftfahrzeug 165/1.
    The surviving Heuschrecke 10 at Fort Sill Field Artillery Museum has got the round holes in the drive sprockets but that was after the restoration because initially it had sprocket wheels with square holes. This can be seen if you look at the pictures of the same tank before and after restoration. (see further discovery about this towards the end!) Which of them that are correct I don't know, but the Heuschrecke IVb was first based on a shortened Panzer 4 and later the Geschützwagen IV chassis and they both, as far as I know, have the drive sprockets with the "square" holes in them by standard.
    Also why are some of them called Heuschrecke 10 and some Heuschrecke IVb?
    Regardless they're all pretty much just prototypes and when making prototypes you use what you have for donor chassis and who knows what configuration, or repairs, they have?
    One final observation is that the sprocket wheel with the round holes are only photographed on the right side and never the left. Could it be that it's got different type sprocket wheels on each side?
    This is something I just discovered and after a fair bit of searching I can only find pictures of a Heuschrecke with round holes pictured from the right side... Are we on to something secret here?
    Good luck with the fabulous build! I will dig a bit further on this to see if I can find a picture with round holes on the left side or if there's some substance to my find.
    • Razzie43
      • Oct 2015
      • 397
      #17
      Lucky me i have the correct wheels on.
      I put the round holes are on the correct side
      • col68
        • 1505
        #18
        Excellent work Michael. Rally like the paint work
          Now I see what you meant by "did wrong" when in fact you were very accurate!
          I didn't initially spot that you'd used different sprocket wheels on your model - just like the only surviving example!
          • Razzie43
            • Oct 2015
            • 397
            #20
            HAHA...indeed....like a third powah into my head says that i have to do that.
            Very strange building i had here.
            Thanks Colt!
              Time to paint the rusty heavy bars.
              Correct the inside of the unfinishd interior turret
              [ATTACH]284886[/ATTACH] [ATTACH]284887[/ATTACH]
              I Cut the axe in pieces to have only the belts left over on the tank
              [ATTACH]284897[/ATTACH]
              [ATTACH]284898[/ATTACH]
              [ATTACH]284885[/ATTACH]
              My local beer to give me the insparation of making it completed
              [ATTACH]284888[/ATTACH]
              All thanks to the bottle of tamiya
              [ATTACH]284899[/ATTACH]
              [ATTACH]284889[/ATTACH] [ATTACH]284890[/ATTACH] [ATTACH]284896[/ATTACH] [ATTACH]284895[/ATTACH] [ATTACH]284894[/ATTACH] [ATTACH]284892[/ATTACH] [ATTACH]284891[/ATTACH]
              Now just weatering the wheels and the tracks and some equipement to finish it of.
              Amazing paintwork, truly stunning!
              • Razzie43
                • Oct 2015
                • 397
                #22
                Friendly comment from the master hail to you John!
                You work inspire me..
                thx m8!
                • Razzie43
                  • Oct 2015
                  • 397
                  #23
                  The bridge working ...
