THe Parts.
[ATTACH]298755[/ATTACH]
[ATTACH]298756[/ATTACH]
[ATTACH]298757[/ATTACH]
[ATTACH]298758[/ATTACH]
Reference material.
[ATTACH]298759[/ATTACH]
[ATTACH]298760[/ATTACH]
[ATTACH]298761[/ATTACH]
Hi I had just started building this when the Mil Mod news broke and if you do not mind I would like to share and finish it here.
I have tried to improve the detail at the top of the boggies, added the 2 missing bolts from the lower arm and added 2 missing grease nipples to the top end of the lower arms.
[ATTACH]297729[/ATTACH]
[ATTACH]297730[/ATTACH]
Assemeled transmission housing.
[ATTACH]297731[/ATTACH]
[ATTACH]297733[/ATTACH]
Assemeled rear engine door panel, air cleaners, replaced handel with copper wire, added weld seams around door hinges , added up & lower hinge pin bungs.
[ATTACH]297735[/ATTACH]
[ATTACH]297737[/ATTACH]
[ATTACH]297739[/ATTACH]
Fitted engine deck,rear air intakes,direct vision ports,F/R ventilators, 5 x armored fuel caps plus missing hinge pins and some PE grills.
[ATTACH]297741[/ATTACH]
Added a splash ring in front of the vision port (is to delect machine gun rounds away from the port)
[ATTACH]297742[/ATTACH]
[ATTACH]297743[/ATTACH]
[ATTACH]297744[/ATTACH]
[ATTACH]297745[/ATTACH]
Thank you for looking.
Pete :sleeping:
