Takom Luchs A1 A2
    • 15677
    Hi Ross
    The underside is so good I'd display the finished model upsidedown!!
    • RM6239
      • May 2018
      • 343
      #17
      Funny you should say that Jim, I found a picture of one on it's roof today.
      cheers
      Ross
        • 22770
        #18
        Coming along nicely Ross, lets hope all the work on the axles wasn't in vane, if it isn't steerable in the end.
        • Lee.M
          • 18
          #19
          Hi Ross
          Nice work on the suspension. Shame to hide it.
          Regards Lee
          • scottie3158
            • 14201
            • Holbeach
            #20
            Ross,
            You off to a great start, will follow along if that's ok.
            Scottie
            • RM6239
              • May 2018
              • 343
              #21
              Ian, Lee and Scottie, cheers guys.
              Got a little bit of time on the bench during the week.
              [ATTACH]301123[/ATTACH]
              [ATTACH]301124[/ATTACH]
              [ATTACH]301125[/ATTACH]
              Fit was pretty good all round though I did run some dissolved putty around the edges. I lost one of the clear periscope ports to the carpet monster and it just didn't want to come back.
              cheers
              Ross
              • rtfoe
                • 9074
                #22
                Looking good Rossco, carpet monster was hungry I guess.
                • JR
                  • May 2015
                  • 18273
                  #23
                  Ross.
                  Those underneath shots ! Good for you mate getting through it .
                  Watch Jim, he will check on your tidy bench, and expect you to keep it like it !
                    • 22770
                    #24
                    cheers
                    Ross
                    Nice work Ross sorry to hear the carpet monster ate your periscope glass. But you could just put some crystal clear across the gap, once dry it should look like class.
                    • RM6239
                      • May 2018
                      • 343
                      #25
                      Richard, yeah I'll probably find it a year from now or something similar.
                      John, cheers mate.
                      Ian, yes I could do that but that leaves a little problem, as you will see.
                      A slight problem has raised it's head, I've run out of CA glue, so I will have to order some in. So I've jumped ahead in the instructions to do what I can bypassing the PE sections.
                      Put together the turret.
                      [ATTACH]302419[/ATTACH]
                      Given the periscopes a blast of Alclad Armoured Glass.
                      [ATTACH]302420[/ATTACH]
                      While I wait for the glue to come in, I'll prime and paint what I can.
                      cheers
                      Ross
                      • Wouter
                        • 742
                        #26
                        Good to see some updates Ross. Looking good there. I like that Alclad Armoured Glass...never heard of it before.
                        • Steve Jones
                          • 6615
                          #27
                          Ross
                          Hope the glue arrives soon. Turret has come along well
                          • RM6239
                            • May 2018
                            • 343
                            #28
                            Cheers Wouter and Steve.
                            The glue still hasn't arrived so I've moved on to painting the lower hull.
                            [ATTACH]303314[/ATTACH]
                            [ATTACH]303315[/ATTACH]
                            [ATTACH]303316[/ATTACH]
                            Decals to add then I can begin the weathering.
                            cheers
                            Ross
                              • 22770
                              #29
                              Camo's looking good Ross
                              • minitnkr
                                Charter Rabble member
                                • 7528
                                • Dayton, OH USA
                                #30
                                It is quite a beast. The red & white striped guards were "required" when traveling on civilian roads. Suspension looks fine after all the difficulties. Looks to be a newer version w/late electronics. The NATO camo sure makes it look the business. Some in KFOR use were fitted with a rear driver position flexible MG. PaulE
