Hello folks - this is another current build that I am on with
I have been waiting a long time for a good T62 to appear and bought two of these as soon as it was released - unfortunately it is not as good as I was expecting
A bit of work is therefore required so here is a catch up to get to the current state......
Turret stippled with Squadron Green Stuff to get a bit of texture
Front wheel arches cut away and track guards thinned right down
Engine deck grilles cut out, louvres installed from micro strip and mesh covers added
One of the worst features of the kit is the shortcut they have taken with the turret ring where it hangs out over the track guards
This should be a sloped casting from the hull, widening out at hull top level
It has been moulded as a solid lump with vertical sides rather than the more usual method of providing the sloping pieces as add on parts
I removed the moulded lump and rebuilt things with Green Stuff and plastic card to get the correct sloped sides
Hull with turret after rebuilding the sides
Gun barrel replaced with a scratch built item made from tubing and filler
The kit fuel drums are not great and lack detail so I scrapped them after cutting off the drum racks
New drum made from tube, brass wire, pewter and filler and strapped down to the recovered rack
For a bit of variety I left off the left drum and made up empty retaining straps from copper sheet
Raised lip added around the turret ring from micro strip
Solid exhaust carefully opened out
Handrails added to turret from brass wire - nothing provided in the kit
Cont.......
Cont.......
