Lee Drennen’s 1/72 Sturmtiger Cmk/ Revell Conversion
  • Lee Drennen
    • 7711
    I really enjoyed building conversion kits this is my first time building a tank conversion,I always liked the looks of this tank. I used the Revell Tiger I for this and the conversion as a Cmk. This is what I have done so far. Enjoy the pics. Lee
ID:	1069607Click image for larger version
ID:	1069608Click image for larger version
ID:	1069609Click image for larger version
ID:	1069610Click image for larger version
ID:	1069611Click image for larger version
ID:	1069612Click image for larger version
  • SimonT
    • 2824
    Hi Lee, I have this conversion in the stash along with a Bergepanther. They look like nice kits
    You have made a bit of a boo boo though - can I suggest you need to reference real photos a bit more
    The superstructure should hang over the edges of the original tank hull - you have gone and sanded the edges off making it flush with the sides. This means the upper hull is no longer the correct shape and looks a bit odd with those rounded lower edges. They should have been sharp and crisp as per the original resin in your third photo
    It could probably be fixed by CA'ing some micro strip to the side to make the stepped edge and then filling to get the shape back
    • Lee Drennen
      • 7711
      Thanks Simon
      I thought it was suppose to be flush I’ll try to strip on it and fix it.
      • Steve Jones
        • 6615
        Ah! The joys of referencing. I spend more time looking at B&W photos than I do modelling.:smiling2: I am sure you will be able to make the necessary changes. Well done:thumb2:
        • Lee Drennen
          • 7711
          Steve tell me about it. Specially when the mold block ends and the part begins. And you never built one. Thanks
          Simon is this better? It’s not a bad conversion but you know how Resin does sometimes. Thanks for the pointer.
ID:	1069634Click image for larger version
ID:	1069635Click image for larger version
ID:	1069636Click image for larger version
          • SimonT
            • 2824
            Hi Lee,
            You need to basically recreate the sharp corners of the resin that you sanded off
            If this link works you should see a pic of how it should end up
            Sturm
            You look to have a good start there - the top edge of the strip needs filling and then the whole lot sanding down so that the slope of the sides goes right down to the lower edge of the plastic
            Hope that makes sense
            • Lee Drennen
              • 7711
              I’ve decided to revisit this build despite its shortcomings I’ve done what I can to correct the resident cast hole so I’m moving on with the build. Today I’ve added a few body parts, Wheels and the Barrel
ID:	1118212Click image for larger version
ID:	1118213Click image for larger version
ID:	1118214Click image for larger version
ID:	1118215Click image for larger version
ID:	1118216Click image for larger version
ID:	1118217Click image for larger version
              • SimonT
                • 2824
                Lee - good to see this on the go again but it has some problems. The front corners of the resin hull should come down to the bottom of the kit sponsons not stop part way up - they need extending
                The securing plates at the front corners with the two big bolt heads look to be on the wrong side and turned through 90deg - the bolts should be vertical on the rear edge of the plate and the bottom edge should also be level with the bottom edge of the sponson
                The upper hull sides still need fairing in with the plastic strips otherwise there will be a visible step
                • Lee Drennen
                  • 7711
                  Simon. Thanks that’s the way the CMK instructions show how they went on I’ll will try to correct that. As far as the strips go that’s as good as it get for me I’m going try to put the bolt heads back on the bottom sides but no promises this is a very back casting with lots of issues I’m doing my best with what I have to work with
                  • SimonT
                    • 2824
                    Hi Lee - not the best kit it would seem. Looks like mine will be getting a rebuild if it ever makes it out of the stash
                    [ATTACH]377371[/ATTACH]
                    reference photo of the Kubinka example courtesy of wiki
                    for the conical bolt heads file a cone shape on the end of a suitably sized piece of rod then slice off
                    • Lee Drennen
                      • 7711
                      Simon. Thanks for all your help I corrected the side plates but I would have been better off to just made new ones. Thanks for the tip how to make the bolt heads I have a piece of rod I think will work. I would buy the trumpeter kit before I would spend the money to deal with this nightmare but I would like to try to finish it. Thanks again
                      • Lee Drennen
                        • 7711
                        Today I finished up putting on the tracks and re-worked the front area also made some new bolts for the sides. I will try to cone shape these when they’re fully set up but no promises
ID:	1118270Click image for larger version
ID:	1118271Click image for larger version
ID:	1118272Click image for larger version
ID:	1118273Click image for larger version
                        • SimonT
                          • 2824
                          Lee - rather you than me trying to shape the bolts once in place :surprised:
                          Good luck
                            I had much the same thought … I had to scroll back up and re-read your advice to make sure I wasn’t missing something about how to make them conical while they’re already on the model
                            • Lee Drennen
                              • 7711
                              I Doubt if I try shape these in a cone it was all I could do to cut and glue them in place with the severe Arthritis in my hands I will clean them up the best I can and call it a day
