Dave Ward's 1/35 HobbyBoss Vickers Medium Mark I
    Whilst on the final approach on my FJ-4Fury ( also by HobbyBoss ), I've opened the box on this, and taken a few detail pics of some parts:[ATTACH]304282[/ATTACH]
    The Hull is in one ( box! ) piece - some nice detail..........[ATTACH]304280[/ATTACH][ATTACH]304279[/ATTACH]
    The turret similarly is in one piece
    [ATTACH]304288[/ATTACH]
    No coaxial machine guns but two Vickers in the hull, and a Hotchkiss that could be swapped around between ball mounts in the turret[ATTACH]304283[/ATTACH]
    Thers's no interior at all, but despite this HB provide PE details for the Vickers breech end ( no no no! )
    This looks more appropriate to a drain cover!
    [ATTACH]304281[/ATTACH]
    Some nice details on the suspension/drivetrain parts[ATTACH]304286[/ATTACH][ATTACH]304285[/ATTACH][ATTACH]304284[/ATTACH]
    I think the real tricky/tiresome part will be the track links
    [ATTACH]304287[/ATTACH]
    I'll need 65 links per side - 260 bits to fit.
    The Vickers Medium Mk I was the first 'mass produced' tank, around 80 were built, but constantly modified as experience dictated. The road wheel axles were fragile, and there are two options for variations in the kit. New Improved suspension bogies were fitted to the Mark II onwards . I hope to start construction at the weekend - somehow I don't think this will be as fast a build as my FJ-4!!
  • Jon Heptonstall
    • 1704
    Interesting model Dave.Look forward to seeing it come togethsr.
    Jon.
      • 22770
      Interesting
      • JR
        • May 2015
        • 18273
        Dave those tracks look like carpet monster food !
        The rest looks fine, doesn't look to be any flash .
        John .
          I have read that it is possible to use Tamiya Matilda tracks as replacement. The 'new' Tamiya Matilda has both 'link & length' and flexible tracks. I'll dig mine out, and have a look, but I want to use the kit parts if possible.
            This one is a first for me:surprised: so you know i'll be watching.
            Tony lee
            • yak face
              • Jun 2009
              • 13829
              • Tony
              Very nice dave , looks to be beautifully moulded , those hundreds of track bits look like a PITA though!! Cheers tony
                • 18892
                Looking like an interesting build so I’ll tag along as well.....tracks could be a bit of a drag though. I would be tempted to stick the little bits on the big bits while the big bits are still on the sprue, it should make some of the handling easier.....depends on the clean up though.
                Tim
                  Tony - HobbyBoss make 4 versions of the Vickers tank, from mine, the Mark I, to the Mark II**, which looks quite different.
                  Tim - yes, I always try to make as much on the sprues as possible, even down to priming.
                  I've located the Tamiya Matilda, so I'll be able to compare the track bits.
                    I assembled a few HB tracks to compare with the Tamiya link & length parts:
                    [ATTACH]304342[/ATTACH]
                    HB on the left. Small differences, but the overall dimensions are the same.
                    The Tamiya model gives you the alternative L & L, and flexible.............
                    [ATTACH]304341[/ATTACH]
                    I am keeping the link & length tracks for the Matilda, but, the flexible tracks I will keep as a backup for the HB model, in case I get really fed up with assembling the individual links. I want to use the kit parts, but it's nice to have a fallback.
                    p.s. the Matilda is the 35300 issue ( the 300th Military model from Tamiya )
                    • eddiesolo
                      • Jul 2013
                      • 11193
                      Very interesting model Dave, lovely finish and moulding as the guys have pointed out, nice work so far.
                        • 15669
                        Hi Dave
                        Looks OK as a kit. One piece hull and one piece turret. They are saving you time for the track :smirk: Someone like Tristar or MiniArt would have had two sprues for the hull and another for the turret!!!
                          Construction started! I'm going to split the construction of the tracks up - 4 sprues, 4 sessions.
                          First track sprue done about 3/4 hr, with P!ink blasting out ( not Pink Floyd ), a bit fiddly, but OK[ATTACH]304450[/ATTACH][ATTACH]304452[/ATTACH]
                          These are not clickable links, I'll do the same as I always do, create straight runs, then fill in with individual links.
                          There is only one colour option, in which HB calls for overall 'olive drab'. I don't think that is correct, so I'm going with the Khaki Green No.3 ( G3 ) from the Hataka Set:
                          [ATTACH]304451[/ATTACH]
                          I've had good results with Hataka paint, so no worries
                          • prichrd1
                            • 691
                            • Conwy
                            Dave,
                            Loving this so far, :thumb2::thumb2:
                            Do you use a hairy stick or the hissy stick with the Hataka paints?
                            Paul.
                            :smiling2:
                              Paul,
                              Hataka Red Line paints are optimised for airbrush, their Blue Line paints are for the hairy stick ( not that I've had any of these Blue lines ). There is an Orange Line, which is a lacquer based paint link: Hataka Site
