[ATTACH]305611[/ATTACH]
[ATTACH]305615[/ATTACH]
This vehicle is destined to be part of my WWII diorama 'Liberation, Italy 1944'.
See the blog at: http://www.scale-models.co.uk/thread...ly-1944.30350/
The last time I built a Universal (or Bren) Carrier was the old Tamiya kit back in the 80s. While it certainly has a lot to commend it (simplicity for one), it is clearly let down by the overly-thick armour (especially in front of the driver's compartment), rubber tracks, etc. So I was looking forward to getting to grips with the (relatively) new 1/35 kit by Riich Models.
I chose the Mark II, probably for nostalgic reasons, because it was the same model as Tamiya's offering. Anyone choosing an Italian diorama before 1944 should probably choose the Mark I, because all the photos that I have seen from that period (of which there aren't many) seem to show the earlier type, although my understanding is that the Mark II was in production from 1942 onwards.
Well, I can certainly say that most of the detail on this kit does not disappoint. Having said that some of the photo-etch (of which there is really quite a lot) is testing, to say the least. The build sequence also needs to be carefully considered, because much of the driver's compartment will be hard to access if none of the interior is painted before the upper armour is fitted.
There are some useful build blogs already on line, although these are predominantly for the Mark 1. However, since many of the components are the same, these are worth looking at which ever version you are building.
For example:
It was from this that I learnt (too late) that there is a (rare) error in the instructions: in step 6 the small axles (D10, D11) and (D18, D19) should be on the opposite sides of the differential from what is indicated in the instructions as they are different lengths.
Otherwise, despite some vagueness elsewhere in the instructions, the kit builds very nicely indeed...
Wheels and tracks
Having assembled most of the interior (and given a coat of paint to the lower inner compartments), I moved on to the running gear.
Here is one of the challenges of this fine kit: unlike the robust (but over-sized) Tamiya equivalent, the wheel assemblies are very delicate. The suspension includes real springs held in place by the pivoted wheel brackets. I had read on-line that these were extremely difficult to tackle and so I had acquired the resin replacements from Sovereign (S2KA020 Bren Carrier Spring Set).
These are beautifully moulded, albeit in a slightly 'artistic' rather then realistic way, and they fit the kit parts perfectly. However, after I lost one resin spring to the carpet monster (and I don't even have a carpet!) I was forced to fall back on the kit's real springs. With considerable irony, I found these to be somewhat easier than I feared. You can spot the odd one out below.
[ATTACH]305612[/ATTACH]
[ATTACH]305614[/ATTACH]
One tip I would pass on to anyone building this kit (or the Mark I) would be to insert brass rod all the way through the hull as a torsion bar for each wheel assembly. This is because the method of attaching the wheels brackets to the hull sides is very weak. My compromise was to drill out the holes a little in the hull and insert short lengths of brass tubing on which to mount the wheels.
[ATTACH]305613[/ATTACH]
For example:
Wheels and tracks
