SimonT - RAM Kangaroo Mk1
  • JR
    • May 2015
    • 18273
    #46
    Should look OK !!!
    They are near perfection in my eye !
    Nice Simon.
    John.
      Originally posted by SimonT
      I know the suspension is not totally accurate
      It would be rather a waste, IMHO, to put so much effort into adding fine details to the kit and then putting six-spoke wheels on it when the real ones had five:
      (source)
      I’m not a rivet-counter, but this is rather more obvious than having 39 bolt heads along a panel edge when there should be 40
        • 15692
        Morning Simon
        You do seem to have a lot on the go at the moment. This is certainly turning into a much bigger project than initially thought.
        • SimonT
          • 2824
          #49
          John - appears not, see Jakko post
          Jakko - I knew the units were a bit wrong size wise but never counted the spokes!
          Bum
          Jim - small amounts on lots of builds as and when I can
            On the positive side, plenty of Sherman kits come with two full sets of roadwheels (or even more), so you can probably get them off someone who doesn’t need the spoked ones and simply put them in place of those you have now.
            • SimonT
              • 2824
              #51
              I have dug out a set of old pre used Italeri 5 spokes which will clean up ok
              The six spoke ones are all glued in nice and solid as I didn't envisage them coming out again :smiling:
              Never mind, a bit of work with the saw and some rod through the Italeri wheels to make a glueable contact patch and I should be in business again :thumb2:
              Thanks
                I had good results removing a Sherman wheel from a bogie with one of those lasercut razorblade saws, as they’re so thin they hardly remove any material.
                • SimonT
                  • 2824
                  #53
                  Wouldn't use anything else - I've long been a user of the excellent JLC razor saw - use it for all part removal from sprues and all other cutting tasks
                  Done one bogie unit as a test - worked ok so will gradually work my way through the others
                    I cut plastic parts from the sprue with cutters or sometimes a knife, except if they look (or turn out to be ) very fragile, in which case I’ll use a saw.
                    As long as they’re not glued to the model yet it shouldn’t be too difficult a job, I’d think.
                    • Steve Jones
                      • 6615
                      #55
                      Glad to see you have sorted the wheels out. Will you bother with the welded numbers and letters on the bogies?
