I'm encountering a problem when putting the hull together, so if anyone else has made one of these they may be able to help?
Looking at the instructions it appears that the front of the upper hull should be flush with the lower hull...like this:
[ATTACH]318036[/ATTACH]
However, if I do this it doesn't fit correctly with the exhaust system:
[ATTACH]318037[/ATTACH]
Now, either I've done something wrong at the back end. Or the upper hull sits on top of the lower hull at the front...thusly:
[ATTACH]318038[/ATTACH]
...which doesn't interfere with the exhaust system at the back. But it does mean there's quite a gap at the front sides by the drive wheels, which surely can't be right...
[ATTACH]318039[/ATTACH]
So I'm a bit stumped with this. I've tried trawling the net for completed model photos...most seem the have the upper hull flush as in the first photograph. I would also assume that that's the right way for it to 'sit' but it's a nuisance it doesn't fit with (what I've done to) the back!
:flushed:
:flushed:
