Don't know about WWII, but I had a friend who back in the nineties subcontracted w/Lima Works to supply them w/vision blocks for Abrams tanks and they were all clear blocks of acrylic when shipped. They may have applied some coating later depending on sensors or humans looking through them. Just some trivia. PaulE
Bowcat's 1/35 Tamiya M40 155mm Self Propelled Gun
(that’s not mine, it’s just a photo I found online). These were used in most American armoured vehicles of the Second World War and the 1950s, and probably later.
Unless you actually look straight into the “window”, that appears dark. This is because when looking at it under an angle, what you actually see reflected in the top mirror/prism (not sure what it is), is the inside of the periscope body, and that’s painted black.
All that said, though, the vision blocks in the hatches on the M40 aren’t periscopes, they’re just glass blocks set in the ring, as this illustration from a tech manual shows:
Well, the hatches are glued on now, so the blocks are staying blue. :tears-of-joy:
Did a little bit tonight. Finished up the binos, hard to tell from the pic but I used clear glue to make lenses.
[ATTACH]324746[/ATTACH]
Got the bodies glossed up ready for a wash. Here they are in some type of bizarre conga line.
[ATTACH]324747[/ATTACH]
And this is where I'm at with the heads. Definitely going to have to revisit some of the eyes, 3 and 5 in particular are going to give me nightmares.
[ATTACH]324748[/ATTACH]Si vis pacem, para bellum.Comment
Who still has that, then?
Like I mentioned earlier, I paint them black and then use a pencil to apply graphite for the shiny effect, which has the added bonus that it’s reflective from some angles but not from others.Comment
BTW Bob, build is looking nice with paint and weathering on.
RichardComment
Agree, the build is looking good.
PeteComment
RichardComment
What we need is a version of those novelty pictures that change when you look at them from under a different angleComment
