Bowcat's 1/35 Tamiya M40 155mm Self Propelled Gun
Cheers guys. :smiling3:
Finished up the figures, mostly all went well other than the kneeling guy. He fell on the floor, dislodging the glued projectile from his hand and tearing the paint. Will need to touch that up. Also glued the pile of projectiles and charge canisters together.
With that done I made a start on the base.
[ATTACH]325188[/ATTACH][ATTACH]325189[/ATTACH][ATTACH]325190[/ATTACH][ATTACH]325191[/ATTACH][ATTACH]325192[/ATTACH]Si vis pacem, para bellum.Comment
Stunning work on the figures. They really look like mini humans at work. Base is looking good also:thumb2::thumb2:Comment
Cheers Steve.
Got some paint down on the base this evening. I primed grey then went over with various shades of brown, flat earth and desert yellow to try and give some variation. I think I'm happy with it, but might adjust a bit after the grass goes down. I will also be going over it with dry pigments for the dusty look, but will do that with the vehicle in place so I can tie it all together.
[ATTACH]325353[/ATTACH]Attached FilesSi vis pacem, para bellum.Comment
