Halftrack to Halftrack
  • scottie3158
    • 14214
    • Holbeach
    #241
    Mike,
    Incredible work.
      breathtaking!
      Cheers Neil, As always, thanks.
      Mike.
        Mike,
        Incredible work.
        Scottie, many thanks,
        Mike.
        • Si Benson
          • 3572
          #244
          Mike,
          I’m truly amazed with your building skills...absolutely excellent!
            Originally posted by Si Benson
            Mike,
            Si,
            Many thanks, not so bad yourself.
            Mike.
              Update,
              Still progressing with the details. I made up two fire extinguisher holders, these will be painted seperately as i want to paint and add the two fire extinguishers to these so that I am not handling the model too much after painting.
              [ATTACH]327479[/ATTACH]
              These will be fitted between the front of the side rack and the door on each side, all now in primer ready for paint. Next it is doors and engine covers, plus another cable adjuster for the jib, hopefully tomorrow.
              Cheers, Mike.
              • Mickc1440
                • 4779
                #247
                Museum quality build, outstanding.
                • scottie3158
                  • 14214
                  • Holbeach
                  #248
                  The extinguishers look spot on.
                    Have you seen the quality of models usually displayed in museums? No museum would want this one — it would make all the other ones they have immediately look like they’re fit only for the bin
                    • Mickc1440
                      • 4779
                      #250
                      Originally posted by Jakko
                      Have you seen the quality of models usually displayed in museums? No museum would want this one — it would make all the other ones they have immediately look like they’re fit only for the bin :smiling3:
                      :smiling::smiling::smiling::smiling::smiling: nice one Jakko
                        • 15733
                        Hi Mike
                        Your scratching is so neat and accurate. The whole build is very impressive. A real credit to your skill and patience.
                        • JR
                          • May 2015
                          • 18273
                          #252
                          Attention to detail Mike is a hall mark of your work. :thumb2:
                          I can see why I stick to distruction .:smiling:
                          Hope Management is improving.
                          John .
                            Mick,
                            Many thanks.
                            Mike.
                              Scottie,
                              Was going to paint them red, but sanity has prevailed, green it is.
                              Or I could start all over again....
                              Mike.
                              [ATTACH]327533[/ATTACH]
                              [COLOR=rgb(209, 72, 65)]For Discussion Only.[/COLOR]
                                Jakko,
                                That is one of a kind comment, and all I can say is thank you.
                                Mike
