Hi Mike the job looks really good, very clever :thumb2:, do you use scribing template much.
Pete.
Hello Pete,
Many thanks for the compliment. The scriber template comes in usefull for those discs that cannot be obtained from other sources, I have other punches but sometimes you cannot get the size so this is where these come in. A few scribes around the next size up usually results in a reduction back to the size you want once the disc is cut out and cleaned up. I will demonstrate with tomorrows update with the pully wheels.
Cheers, Mike.
Hello Pete,
Cheers, Mike.
I'll be there with my note book at the ready.
Pete.
Looking good Mike.
In fact the dogs ! :thumb2: Don;t you just love it when it works.
John.
Ha, Ha, Got a length of brass wire out, great thought I, that will do to make the cable guard on top of the roller half way up the jib. Just a simple U shape 8mm wide. Eight attempts later, lots of U shapes, too big or too small, but got it in the end.
Comment very welcome,
Cheers, Mike.
Cheers, Mike.
Mike
Do you know that makes me feel I'm not alone, I was making some handles for my second build a few years back, it was the KV2.
I had handles everywhere, all differing widths, then I had a brain wave, why not measure the width first. :nerd:
John .
Mike
John .
Update,
Today, was make a pully wheel day.
You come to a point where the Punch & Die set just will not give you the size you need, other tools will give the same result. Then it comes down to the 'P' Cutter, but even that has it's limits. So in between all of that are the templates. I first got my hands on mine a few years ago and have been either on the bench or in the tech drawing tools at college (some say mature student, but I would add an I ).
[ATTACH]320551[/ATTACH]
And as you can see there is quite a selection from leather punch through to templates. Also required is a scriber of either your own design or from a manufacturer.
[ATTACH]320552[/ATTACH]
And today is one of those times when I need to scratch build the pully wheel.
To start the card is sanded to remove the gloss surface, that enabeles the pencil line not only to be more visible, but remains on the card a lot longer.
First mark out the size you require, in this case it is 5mm diameter and then from corner to corner to find the centre. This is then drilled out to save trying to find it later, it also aids in lining up two discs or more. As in this case 3 per pully wheel. The template is laid over the square, but a half mm larger is chosen. This is to allow for the thickness of the scribed line. So in this case for 5mm I chose 5.5mm and duly set off scribing the line.
[ATTACH]320553[/ATTACH]
Once the disc is scribed about halfway, it can be finished off with the tip of a sharp knife - scalpel with #10A blade and just using the tip with no heavy cutting, (although I have been known to us a Stanley knife) and this should release the disc. Another meathod is to cut as close to the scribed line and then break away the excess plastic....
[ATTACH]320554[/ATTACH]
...and then shape to finish. You can check the size of the disc with the template as you go along.
[ATTACH]320555[/ATTACH]
And once satisfied with your work either complete the pully wheel or attach the disc as you want.
[ATTACH]320556[/ATTACH]
[ATTACH]320557[/ATTACH]
So pulley wheels now in place, it is time to add the cable attachment points at the top of the jib, make up the hook and add that then move on....
Thanks for looking.
Cheers, Mike.
