Halftrack to Halftrack
Update,
The light fittings are now in place, so work can proceed a bit more and added the flourescent light bulb tubes, but they will go in after the interior is painted.
[ATTACH]320773[/ATTACH]
[ATTACH]320774[/ATTACH]
The hook is just about finished, just a bit of cleaning up to do. I did replace the pully wheel at the end of the jib, the one in place looke a bit on the small side (photo later).
[ATTACH]320775[/ATTACH]
The odd angle of the plate is intentionable to add a bit of repair work. And that is it for today - now it is wheelie time on the AVLB.
Mike.Comment
Update,
The new pulley wheel pic is below,
[ATTACH]320798[/ATTACH]
Got tired of cutting wheels of sprue and cleaning them up, so decided to add the stowage hooks and then the extractor fan and guard.
[ATTACH]320799[/ATTACH]
[ATTACH]320800[/ATTACH]
Yet to be primed and painted after some more details.
Cheers, Mike.Comment
Hi Mike, it's been said before your eye for detail it truly amazing and the work you are producing is just stunning and I'm very happy you have come back to build this top class work :thumb2::thumb2::thumb2:.
Pete.Comment
Update,
Today, was make a pully wheel day.
You come to a point where the Punch & Die set just will not give you the size you need, other tools will give the same result. Then it comes down to the 'P' Cutter, but even that has it's limits. So in between all of that are the templates. I first got my hands on mine a few years ago and have been either on the bench or in the tech drawing tools at college (some say mature student, but I would add an I ).
[ATTACH]320551[/ATTACH]
And as you can see there is quite a selection from leather punch through to templates. Also required is a scriber of either your own design or from a manufacturer.
Cheers, Mike.
Your scratchy stuff is wicked man and impressive. I'd be taking meds perpetually if I scratch build like you have.
RichardComment
Mike, I got my aluminum templates from my wife when she gave up her interior designing career to look after our daughter. Nowadays the computer has taken over drafting on tracing paper. The templates have been really useful for scribing aircraft panels. Used them to cut my pulleys for the Walrus catapult that I scratch built.
I remember your excellent build on the Walrus catapault from the old site and I still have the plans. True about the computer taking over, I worked for a short time in the mock up shop for BAe at Hatfield on the 146 and A300/310 wing among other items, and even then the CAD was just coming into the workplace mainly for drawings but later for modelmaking.
The meds are there - I keep banging my head against the wall :face-with-head-bandage: .
Update,
The interior upper part is now complete apart from a wash, I have tried to replicate an area that really was not looked after, old vehicle and all that and with a few repaints one on top of the other.
[ATTACH]321112[/ATTACH]
The cage for the fan has also been added as has the florescent light bulbs.
[ATTACH]321113[/ATTACH]
[ATTACH]321114[/ATTACH]
And as for the rest there is plenty of priming on the go plus other items like ropes, chains, vice, compressor etc still to build/add/paint.
Thanks for looking,
Mike.Comment
Hi Mike, this is getting better and better, love the look of those florescent tubes, just one thing can't see the starters for the tubes, I'm only joking.
Hope you feel better soon.
Pete.Comment
Mike.Comment
Update,
A bit more painting and detailing on the work area, the air lines for the welding bottles, some old ropes, chains and bottle jack added. Still got the vice and compressor to add and then I am going to seal it all up.
[ATTACH]321168[/ATTACH]
[ATTACH]321169[/ATTACH][ATTACH]321170[/ATTACH]
Still some painting to finish off, but you can keep going forever adding.
