This one was first started five or more years ago then put to one side in favour of something else.
It was resurrected for a short time at the end of last year then fell by the wayside again.
Nearly a year later it has floated to the surface for another go....
A catch up on progress to date:
[ATTACH]320508[/ATTACH]
the kit in question is this vintage Tamiya - it had been sat in the stash for a large number of years
[ATTACH]320509[/ATTACH]
motorisation holes all blanked and filled, sponsons blanked off
[ATTACH]320510[/ATTACH]
engine deck louvres scratched
[ATTACH]320511[/ATTACH]
managed to lose one idler wheel so had to scratch a replacement
[ATTACH]320512[/ATTACH]
poly hubs replaced with scratched items from plastic card and pewter
[ATTACH]320513[/ATTACH]
gun barrel made from aluminium tubing, new lifting eyes from brass wire, new track guards from copper sheet, cast texture added from stippled on vj filler
New things added over the last couple of days
[ATTACH]320514[/ATTACH]
Eduard etch grilles added after carving out the kit parts (hard plastic so took a while) , fuel can rack added to left side (the started ones on the right will be removed and replaced)
[ATTACH]320515[/ATTACH]
[ATTACH]320516[/ATTACH]
the tracks will be replaced with Masterclub resin versions - about half the links are already cleaned up from one of my previous sessions
Still quite a few things to sort out but hopefully I will actually get it finished this time........
