SimonT - 1/35 SU-122
    • 15692
    Hi Simon
    Well it's been a while but great to see this again.
    • minitnkr
      Charter Rabble member
      • 7537
      • Dayton, OH USA
      #62
      A beautyiful piece of work. PaulE
      • scottie3158
        • 14201
        • Holbeach
        #63
        Simon,
        Great work as always.
        • SimonT
          • 2824
          #64
          Rick, Jim, Paul, Scottie - ta one and all. Has been around for some time now so should really try and finish it off
ID:	1126431Click image for larger version
ID:	1126432Click image for larger version
          the rack are progressing - looks like a couple have snapped at the change in direction from curve to the flat part at the top so will need a little tidying up
          • Strenko J
            • May 2018
            • 752
            • Joe
            • Pittsburgh PA
            #65
            Well done Simon..really enjoying the scratchery.. what did you use for the rivets?
            • SimonT
              • 2824
              #66
              Hi Joe - if you mean the ones on the rear etch grille they are lead foil punched with The Nutter punch set
              • Strenko J
                • May 2018
                • 752
                • Joe
                • Pittsburgh PA
                #67
                Yes those were the ones.. I am working on an old Tiger I tank from Tamiya...(ughhh,,yes the old motorized version) and I’ve been adding some bling with photo etch and other scratch stuff.. still have to add some additional bolts in many places. I have been using plastruct octagon shaped rod and cutting them with The Chopper... very tedious but def gives it the better look.. going to try some foil to see which I like working with better.. thanks for the input
                • SimonT
                  • 2824
                  #68
                  Have one of the old tigers lurking in the stash somewhere
                  I sometimes use that hex rod for the 0.5mm
                  For larger sizes I have a couple of hex punch and dies sets
                  Is your build on here Joe?
                  • Strenko J
                    • May 2018
                    • 752
                    • Joe
                    • Pittsburgh PA
                    #69
                    Not yet...have not been able to make a lot of progress so I didn’t want to post anything yet
                    • Mini Me
                      • Jun 2018
                      • 10711
                      #70
                      Those cradles are the "DOGS" Mr. T. What's the smallest hex punch and die set and who makes them?.....very curious about the possibility of using them in 1/87 scale if possible. Rick H.
                      • SimonT
                        • 2824
                        #71
                        Hi Rick
                        the smallest hex punch I have is 0.5mm and that would be a US product by The Small Shop called The Nutter
                        It only works with their own Tri-Foil, a special soft lead foil sandwich. The foil is quite thin which makes it better suited to the smaller scales in general
                        0.5mm / 0.0196" equates to a bolt/rivet of 43.5mm / 1.72" in 1/87 which would be quite large
                        The Nutter set also comes with a round punch at 0.25mm / 0.0098" which equates to a bolt/rivet of 21.75mm / 0.85" in 1/87
                        When you get down to this size it doesn't really matter about it being round (you wouldn't be able to distinguish between round or hex) so you can use it to represent bolt heads or rivets
                        Conventional punch and die sets that can be used with any material you can get in them, but typically plastic card, don't go down this small
                        I have a UMM-USA hex - that only goes down to 0.8mm and the RP Toolz hex set which goes down to 0.7mm
                        UMM-USA round and RP Toolz round both go down to 0.5mm
                        I have not come across anything smaller than The Nutter 0.25mm round and doubt we ever will due to how fragile they would be
                        • Mini Me
                          • Jun 2018
                          • 10711
                          #72
                          Thanks for the information Simon, I will look into it further as I am interested in producing rivets and bolt heads where needed in 1/87. I'm not a rivet counter but sometimes they are essential when scratch building or adding a modification to an existing model.
                          Cheers, Rick H.
                            • 18903
                            I used to use cubes of 15thou plastic card when scratch building in 1/76.2 for model railways....but you have to cut your own plastic strip because nobody makes anything that fine. Anything smaller will probably dissolve away when you glue it on....
                            • Steve Jones
                              • 6615
                              #74
                              Nice build update and details on the rivet punching Simon. Thanks for sharing
                              • SimonT
                                • 2824
                                #75
                                No problem Rick
                                Tim - I use CA so they don’t dissolve
                                Cheers Steve
