SimonT - 1/35 SU-122
  • SimonT
    • 2824
    #76
    Last night I added all the tank strap mounting brackets to the tank brackets
    two L shaped brackets with a hole drilled in one leg of the L that the strap mounts through
ID:	1126525Click image for larger version
    the tank straps comprise a flat metal strip with threaded rod welded on each end - the threaded rod passes through the hole in bracket
    • SimonT
      • 2824
      #77
      Morning all - more work done on the fuel tanks yesterday
      retaining straps - sliced a 1.5mm wide strip of plastic card then cut that into 28mm lengths
      added 4mm lengths of 0.5mm rod for the retaining bolts
      the straps were then installed by pushing the bolt ends through the holes in the brackets
      I then punched a load of hex bolt heads and drilled through them so that they could be pushed over the strap bolts and glued in place
      would have put a thread on the bolt ends but I have misplaced my jewellers tap and die set
      • Mini Me
        • Jun 2018
        • 10711
        #78
        Thought you would never get round to the part about the scale threads on this......I guess we'll have to settle for the old slip joint method:tongue-out3::rolling::thinking: Rick H.
        • SimonT
          • 2824
          #79
          Hi Rick - I searched all over but couldn't locate the tap and die plate. No doubt now it is too late it will magically appear again
          • scottie3158
            • 14201
            • Holbeach
            #80
            Simon beautiful details as always mate.
            • Lee Drennen
              • 7711
              #81
              Simon. Beautiful scratch as always
              • minitnkr
                Charter Rabble member
                • 7531
                • Dayton, OH USA
                #82
                Grant Line used to provide 1/87 nut/bolt assys. Still have some I think. Like Simon says, some plastic glues/cements will melt them. PaulE
                • Mini Me
                  • Jun 2018
                  • 10711
                  #83
                  Grant line is good but sometimes too large for my purposes.......makes small assemblies look clunky......working on a solution though. Rick H.
                  • SimonT
                    • 2824
                    #84
                    Cheers Scottie
                    Thanks Lee
                    Paul - I did get a large assorted box of Grandt Line nuts, bolts, hinges, lifting eyes, and the most useful wing nuts back around 1990. Pretty much only have the odd sized stuff left that will probably never be useful for anything! Tried to find their wing nuts recently but nothing doing - think they have gone bust from what I read
                    Rick - much more suited to 1/35
                    I think my body clock has a broken mainspring - been exhausted tired all weekend for no good reason and as a result spent most of it asleep. What a waste of a weekend.
                    Only really woke up around 6pm Sunday so not much done on the modelling
                    Did make a rather nice looking loaf though - finished baking just after midnight. All I can smell now is bread - yum
                    brass handrail added to rear of superstructure - kit one was broken any way
                    supports are from brass wire flattened with smooth nose pliers, wrapped around the rod and nipped up with the pliers
                    headlight added
                    horn hollowed out and added to the headlight bracket
                    the solid plastic kit tree saw holder replaced with a copper one - a 3mm strip was cut then folded up in an etch folder to make the U shape channel that it should be
                    No tree saw provided so may have a look at making one
                    filler caps added to the fuel tanks
                    track pin bashers added just in front of the final drive housing - loose track pins hit the steel block and get pushed back in to the track link
                    Presumably this only works for so long until the pins wear so loose they fall out before the track gets back around to the block
                    • Lee Drennen
                      • 7711
                      #85
                      Simon. Details look very nice and don’t beat yourself up I’ve had lots of those weekends
                      • Steve Jones
                        • 6615
                        #86
                        For someone who has been asleep all weekend you still manage to pack a creative punch Mr T. Some lovely additions. It's coming along a treat
                        • BigGreg
                          • 2182
                          #87
                          Splendid work
                          • SimonT
                            • 2824
                            #88
                            Thanks Lee - really annoying, wait all week for the weekend then sleep through it :rolling:
                            Cheers Steve - getting there gradually. There was a lot more left to do than I originally thought
                            Thanks Greg
                            knocked together a tree saw and started cutting in some teeny tiny teeth until I remembered that once in the rack only a few teeth in the centre are visible
                            looks rubbish at this size but the teeth are only about quarter of a millimetre in reality so it doesn't look quite so bad on the vehicle
                            this is it in the rack
ID:	1126780Click image for larger version
                            broke the kit shovel so added an Armour Accessories one instead
                            managed to get the fuel tank straps a bit straighter
                            when I made the racks I was struggling to find pictures of these earlier style racks - I have tons of T34/85 pictures but the racks on them are a totally different design
                            Typically I found some pictures of early racks last night on an SU-100 so have modified the racks slightly to allow the straps to move sideways - not perfect but I am much happier with them now
                              • 15686
                              Hi Simon
                              As always amazing scratch building. Really looking good. I reckon if you're sleeping through the weekend then you're working too hard during the week :tongue-out3:
                              • SimonT
                                • 2824
                                #90
                                Could be Jim - I need to sleep more at work :thumb2:
                                Only progress has been to add a radio aerial, a vision port on the rear of the superstructure and fill two small holes - not worth a photo
