Tracks finished, and fenders attached.........................[ATTACH]327284[/ATTACH][ATTACH]327285[/ATTACH]
Proceeding apace, when the superstructure is added, I'll spray the upper hull - not that many big bits to add.
Hello Dave,
Phew, caught up again, love the tracks and they will look so realistic under a coat of paint.
Seat reservation made for next episode.
Cheers, Mike.
I've added all the PE ribs on the fenders, and the rear decking has had its doors & bits added. I'm using leftover PE parts from a previous KV, for the rear deck grilles. I simply had to dry fit the superstructure............. [ATTACH]327429[/ATTACH][ATTACH]327428[/ATTACH]
The fit is really good - I was worried that I would end up with large gaps to fill.
So far, the parts have needed minimal clean up, and the fit is very good - I must say that a well-engineered model is a real joy to work on!
Assembly almost finished - just the tools to add, ( and headlamp ) & towing parts[ATTACH]327502[/ATTACH][ATTACH]327503[/ATTACH]
Next, prime the upper hull, nearly complete.
It's a very dark gloomy morning, here in Gloucestershire - just as well that an overall black primer coat doesn't need much thought to apply![ATTACH]327560[/ATTACH]
Cornflake packet masks inserted between tracks & fenders. IF the light improves I'll do a first pass basecoat of green later...................
Hopefully, a minor pause in benchtime. I had a slight accident yesterday, and today, I've a stiff and aching right hand and arm, and a nasty bruise on my back, which is causing me grief when I move. Stupid overbalance, slip and fall. No alcohol involved! - at first I thought I hadn't done anything, but as the day wore on, I got stiffer & stiffer.
Have to hit the Ibuprofen, and have an early night.............................
