Shenanigans 3: Tamiya M8 and Willys Jeep
  • rtfoe
    • 9101
    #46
    Peter...you'going so fast that I'm just about to comment on the M8...what's there to comment, it looks just like what the other guys do with armour here but I can see your touches on the storage painting. Nice work.
    ...now where should I start on the Jeep. :thinking:
      Fernando - Many thanks for looking in.
      Jakko - Yes, that is an option, and I have done it in the past. However, I hoped that the carbine mounted above the dashboard would cover the worst part of the windscreen, as indeed it has. Phew!
      Richard - Thank you. I'm a long way behind the majority of armour modellers here though - it's not easy is it?
      I took advantage of better light to re-photograph the M8:
      [ATTACH alt="328543"]328543[/ATTACH][ATTACH alt="328544"]328544[/ATTACH][ATTACH alt="328545"]328545[/ATTACH]
      On to the jeep, and the main build is done:
      [ATTACH alt="328546"]328546[/ATTACH][ATTACH alt="328547"]328547[/ATTACH][ATTACH alt="328571"]328571[/ATTACH][ATTACH alt="328572"]328572[/ATTACH]
      I started today's session by weathering the basic build before adding the decals and equipment, which were weathered in after fixing to match. As mentioned, the carbine mounted above the dashboard hid the worst of the windscreen fit, which was a relief. I decided to go for the 30 cal option as it adds a bit more interest.
      I also decided to use the wire cutter provided. Tamiya just supply one length of triangular bar, and as most seem to have had bracing struts added, I decided to make some from scrap plastic. Most of this type of modification was done in the field using whatever was available, so I've tried to depict it as un-painted and slightly rusty looking.
      I also managed to make a couple of bonnet clasps from entrenching tool handles mounted on card plates. Unfortunately I didn't have enough to make the clasps used for securing the windscreen, so perhaps they were never fitted in this case. Also needed was a bit of extra strapping for some of the equipment which was not represented.
      Here's how the vehicles look together:
      [ATTACH alt="328552"]328552[/ATTACH]
      The next stage is to add some stowage to the jeep.
      • Mike Mortimore
        • 202
        #48
        Hi Peter,
        Brilliant builds. How did you get the weathering to look so subtle. Like a light covering of dust...... Italy campaign......
        Regards Mike :sleeping::sleeping::sleeping::sleeping::sleeping:
          Thanks Mike - Any 'subtlety' is probably down to timidity, if I'm honest. I've used a whole range of colours, from black, through a range of greens to white, but I think building up the tones gradually has evened out the effect somewhat. However, I've never been a fan of heavy weathering, preferring instead to try and bring out the details of the vehicle.
          I've sorted out the stowage for the jeep:
          [ATTACH alt="328562"]328562[/ATTACH]
          At least a day's work there.
          • Si Benson
            • 3572
            #50
            Hi Peter,
            As I’ve said before, I very much enjoy your subtle style on the Vehicles and the jeep is no exception.
            Pure eye candy:smiling4:
              Many thanks Si. The stowage should lift it a bit.
              • scottie3158
                • 14221
                • Holbeach
                #52
                Peter,
                Very nice looking vehicles, top work as always.
                • SteveH
                  • 1287
                  #53
                  Morning Peter
                  Lovely work on the jeep, well done.
                  Timidity in weathering, shouldn't be an issue, especially if the final result looks so good.
                  The current Vogue seems to be for extremes in both weathering and chipping, which are the builders prerogative, as it is a hobby.
                  I guess it will eventually come full circle back to subtle, rather than ""in your face""?
                  Possibly figures as well as jeep accessories today?
                  Its all warmer, grey and wet now, up North.
                  Have a good day with the paint
                  Regards
                  Steve H
                    Probably, though the chipping trend of the past 15–20 years shows no real signs of abating, if you ask me. I just think it’s usually far overdone for a realistic finish. Dirt and grime, on the other hand, can realistically be as little or as much as you like for a lot of military vehicles.
                      Scottie - Many thanks to another master.
                      Steve - Very wet and windy here, but warmer. Weathering is a subjective thing and down to the individual. However, there is a bit of pressure to conform to the latest trends, which makes it difficult for the average modeller to achieve a finish they are happy with. Less is definitely more in my opinion.
                      Jakko - I agree, chipping is one of those 'trends'. As you say, the amount of weathering you go for is a personal thing and I prefer to 'suggest' context rather than overwhelm the vehicle.
                      • JR
                        • May 2015
                        • 18273
                        #56
                        Peter.
                        One look at those photos shouts out Peter Day, the painting is perfect, the detail brush work on the materail, be it the seats or the tarps and packs is done with finesse. Your hall mark.
                        I can image how they good look in the flesh just by looking at the figures you sent some time back .
                        Has to be a :thumb2::thumb2::thumb2::thumb2::thumb2: from me .
                        John .
                          Very many thanks John - very kind words.
                          The jeep is finished:
                          [ATTACH alt="328659"]328659[/ATTACH][ATTACH alt="328660"]328660[/ATTACH][ATTACH alt="328661"]328661[/ATTACH][ATTACH alt="328662"]328662[/ATTACH]
                          I went for it with the stowage, adding seventeen items to give the thing a cluttered look and to try and bring it to life a bit. Now cross-eyed and half blind.
                          On to the figures.......
                          • minitnkr
                            Charter Rabble member
                            • 7553
                            • Dayton, OH USA
                            #58
                            Well done Peter. Very precise builds. PaulE
                              Thank you Paul.
                              The figures are ready for painting, bar a bit more cleaning up:
                              [ATTACH alt="328690"]328690[/ATTACH]
                              • Peter Gillson
                                • 2594
                                #60
                                A fine looking Jeep
