Dave Ward's Trumpeter 1/35 IT-1 Missile Tank - stalled build resumed!
    John,
    I find it easier to clean up & retouch the sprue attachments, instead of creating a forest of wheels on cocktail sticks. It works nicely with the IT-1, with it's separate tyre rims.
    After a mornings work ( OK, I had 2 cups of coffee, ans a Tesco delivery.....), the majority of work is done on the tracks. The IT-1 doesn't have any return rollers, so a simple curve for the top run will do.Click image for larger version
    I was careful, in cutting the links off the sprue - and I only had to clean up about 5 links for fitment. It pays to have a good sharp sprue cutter - and nice clean mouldings help! I must say I enjoy putting these larger links together - I just used a straight edge & TET
    Time to prime!
      Tracks primed & one side completed - I miscalculated the number of tracks, and had to add the extra links ( the unpainted bits ) - still, better adding, rather than subtracting.Click image for larger version
      As far as individual track links go this has been pretty easy........................
        That's the lower hull, and running gear complete - I can now move on to some more interesting bits.....................................Click image for larger version
ID:	1086700Click image for larger version
        I eventually had 14 links spare.
          Nice looking sag, very natural .
            I tried to convince my now ex-wife that those very words were a compliment.:tongue-out2:
              Ran,
              You really like hospital food that much?
                Ran,
                Tapioca pudding oop:
                The tracks really do look great, nice work.
                  • 22788
                  #23
                  Looks a good kit Dave and nice work so far.
                    The basic hull and running gear are the same as the Trumpeter T-62 I have in the stash, it'll be the upper bits that are different. Fit is excellent, even the tracks fitted with next to nothing in the clean up. I originally had one track link less in the top runs, but that looked too tight, so I added one more, and that looks a little slack. Since I couldn't have a half link, the slack look has prevailed.
                      Progress - upper hull added, and the fenders. Pretty much standard T-62 bits. Click image for larger version
ID:	1086765Click image for larger version
                      PE used for good effect, grilles! The IT-1 has a number of stowage boxes unique to it ( no room inside? ) Still no fit problems....................
                        A few more additions - and the hull is finished!Click image for larger version
                        Tomorrow, the turret! Pretty soon, I'll be beginning to decide what the next build is
                          Looking good Dave:thumb2:!
                            The turret is finished - just waiting for the prime coats................... Click image for larger version
ID:	1086804Click image for larger version
                            The missile will be painted a slightly different green.........
                            Turning to my next build, I'm torn between two models.....................Click image for larger version
Name:	bronco 35(t).jpg
ID:	1086807Click image for larger version
Name:	vulcan light tank.jpg
                            I'm going to peruse the box contents over the weekend, and decide
                              First Basecoat - I overthinned the paint, and in consequence it's a little patchy in places, but I'll correct that tomorrowClick image for larger version
ID:	1086813Click image for larger version
                              The only thing missing, apart from the missile itself is the big unditching log, that all Soviet tanks carried - it's always a bit tricky, painting.............
                                Now happy with the basecoat - then I realised I had left off the rear fender sections on both sides!Click image for larger version
ID:	1086842Click image for larger version
                                Next, some detail painting, then an overall varnish spray before some washes - no decals!
