Sd.Kfz. 179 Bergepanther. Italeri 1/35
    Coming along nicely.
    • minitnkr
      Charter Rabble member
      • 7551
      • Dayton, OH USA
      #32
      Couldn't find a real photo, but this shows (for discussion purposes) what I was trying to convey. Also shows the boards. Too late, but for future ref. PaulE
Name:	BP cover.jpg
      • Peter Gillson
        • 2594
        #33
        The recessed grab handles on the floor boards is really nice touch.
          • 18271
          So been tinkering away here and there. Got a few bits done and threw some paint at them. As I have chosen not to beat the carp out of this one, I will do any chipping 'after the fact'.
          So:
          The barrel of the main gun was, to put it bluntly, naff. The mould seam was so bad that after getting it sorted, the barrel was very oval. So I took the plunge and made a new one. By no means brilliant but better than what there was left of the kits barrel- At least it is straight and round.
          Much to my amusement the cable I made was to short. so After stripping a metre of wire I made a new one. Just need to paint the bugger then touch up and weather the winches.
          The driver compartment is just awaiting some oil, grime and a bit of 'charm' Funny, All the detail is right at the front where you cant really see it. At the rear where you can see there is next to no detail I will have to find something to change that up!
          Still plenty of things to address while waiting for the PE fret. Like adding the missing rain stop thingy from around the cab opening. Tons of weld seams to add as well....
          Oh and make the periscope glasses, which Italeri did not think where required in the kit.
          Question: Clear or coloured? I am guessing the multi coated armoured glass is a more modern thing. What say the experts?
          TTFN
            Periscopes were plain glass colour until the 1990s or so. Pink and other coatings are mainly an anti-laser measure, for which there was no real need before then, and certainly not in the Second World War due to lasers not even existing at the time
              • 18271
              Thanks Jakko I was pretty sure they where a newer idea. Didn't think that they were that resent though.
              Any how.
              Started to tart the driver compartment up a bit. Nothing fancy, just a few bits that can clearly be seen if you peer down the opening.
              A question. The Green Boxes on either side of the winch room. I guessed they are tool boxes.....but they are not are they. Are they fuel cells? If so what colour should they be?
              Added a few more weld seems and added the missing studs with a bolt to the swing covers.
              And the crane arm mounts. Just need to weld the tool racks in place.
              A couple of cleaned up bits awaiting a visit to the paint shop.
              Oh! I kinda cut a hole in the bulkhead between the winch and driver compartment.
              I must admit that I am rather disappointed with the crane boom. All moulded in one part. makes it rather difficult to pose. Also hard to put on the other side of the hull.
              Can't find an aftermarket one so am considering making a whole new one.
              More later...
              • Mini Me
                • Jun 2018
                • 10711
                #37
                Probably not a bad idea if it's not too complex. Or you could call in one of our resident crane masters...lol:smiling5:. Suggestion: A couple of personal item in the drivers compt. would be interesting if they would be visible. That lip you added around the drivers compt. is a detail I didn't pick up when I was looking at photos of this vehicle. Good Eye! Cheers, Rick H.
                • Si Benson
                  • 3572
                  #38
                  Hi Ian,
                  Coming along nicely. Taking notes as I got one of these in the stash too:smiling4:
                    Ian,
                    Coming along very well, as Jakko said with the periscopes they were just plain glass backed up with mirrors, same as the things you made at school, bit of a bugger when moisture got into them.
                    Some very nice detailing work going on as well to add interest.
                    Cheers, Mike.
                      • 18271
                      Thanks for the encouraging words.
                      Mini Me there are so many that had unit level custom changes, you can almost do what you want. The bulkhead between the winch and driver compartment a good example. From hatched and sliding doors to just a hole.
                      Guest Cheers, still trying to find some clear plastic to whittle some out of.
                      Si Benson Trust me, If I had the choice, I would have gone for the Takom or Meng job. I got this in a job lot yonks ago.
                      Any how. About this crane/boom. After a lot of trial and epic fails, I decided to do an 'easy' fix. All the booms where measured off and then cut out leaving just the brackets. Those were drilled out and brass rod or tube CA'ed in. Bent up a hook for the top of the mast and made a rod with two soldered eye loops. A length of chain was the hard part. ended up buying a chain from a hobby shop. (For making necklaces with)
                      It might look OK with a bit of paint on. The Winch siding is only loose at the moment to make sure all fits and nothing is in the way.
                      Hope to get the PE fret soon so I can get the grills on and a few other bits. I must say that generally the plastic parts are pretty good and after a bit of clean-up and accentuating work as well as the PE will. I have had to buy it though as the Kits PE was missing and I needed the grills for the motor room vents.
                      Then I can start painting the thing.
                      Pop quiz:- Plain Yellow or three colour?
                      Cheers.
                      • Mini Me
                        • Jun 2018
                        • 10711
                        #41
                        Three color would be my choice!
                        Cheers, Rick H.
                        • minitnkr
                          • 7551
                          • Dayton, OH USA
                          #42
                          Mine too. PaulE
                            Great modelling Ian.
                            • scottie3158
                              • 14221
                              • Holbeach
                              #44
                              Ian,
                              The jib looks very good with the changes you have made. 3 colour for me as well.
                                [ATTACH=CONFIG]n1086967[/ATTACH]
                                [ATTACH=CONFIG]n1086968[/ATTACH]
                                Cheers.
                                Old CD cover....
