Shenanigans 5: Tamiya PzKpfw IV Ausf D
    [ATTACH alt="330316"]330316[/ATTACH]
    OK, let' see how this one goes.
    After the failures of my Tamiya T-34 and Italeri Dodge, I said that I was going to be wary of old kits. However, beggars can't be choosers, and at a price of £17, this seemed worth getting, even though it's dated 1977 on the box and 1975 on some of the sprues. I've also built it before, so I know it can be done!
    The kit has parts for an early version, later version with additional armour, and a DAK version with additional engine vents and turret bin. The sprues:
    [ATTACH alt="330317"]330317[/ATTACH][ATTACH alt="330318"]330318[/ATTACH][ATTACH alt="330319"]330319[/ATTACH]
    The figures are not brilliant, but adequate, so I'm going for something straight out of the box.
    Off we go......
  • SteveH
    • 1287
    Afternoon Peter
    I seem to be late to all the parties!
    The Pandour officer looks really cool if not a little odd with a 3 tier thing on his head but cracking finish.
    You really are a glutton for punishment or a slow learner with the old kits and 1:35 figures!
    There's pain ahead, but at least the old Tamiya Pz IV D only has dimensional issues and still builds into a "tank"
    Have a fun day building
    Regards
    Steve H
      Go for it Peter, your masochistic tendancies are coming to the fore. Will look in later. Cheers, Mike.
        Steve - As long as it looks roughly like a German tank, I don't mind. As you've probably gathered, I'm no expert! I appreciate that such an old kit is likely to be pretty inaccurate, so I hope you'll indulge me.
        Mike - I remembered this as being fairly straightforward when I first built it, so hopefully it won't be too painful.
        This is where I've got to with it:
        [ATTACH alt="330348"]330348[/ATTACH][ATTACH alt="330349"]330349[/ATTACH][ATTACH alt="330350"]330350[/ATTACH]
        The basic hull and running gear are done and everything that will be painted grey has been attached. I've also used the extra armour plates, which I think gives it a lift.
        The running gear was much stronger than that of the T34 I binned, but the idlers were still a bit flimsily mounted to take the strain of the vinyl track. I therefore had to add some packing to the mounts to strengthen them. I also had to add a piece of trim to the inside edge of the aerial trough as it was damaged by the sprue attachments.
        The undersides and running gear have been given a coat of black/brown as a base for a muddy finish and the upper parts have had a coat of Vallejo German Grey.
        • scottie3158
          • 14208
          • Holbeach
          Peter,
          Chair pulled up, trouble is by the time it get comfy you have already finished them:smiling:
            On you marks get set............give us a chance :tongue-out3:.
              Hi Scottie and Ralph. Don't worry, nowhere near finished and I will slow down a bit from now on. I always get anxious about the running gear and whether the deck will fit, so once they're done I can relax.
              • scottie3158
                • 14208
                • Holbeach
                Peter, No worries I wish sometimes I could get them built quicker than I manage.
                • Steve Jones
                  • 6615
                  This is my only shelf queen. I had great plans to build two at once a couple of years back but made a right hash of trying to correct the front sprockets. If you need any spares for any of this build let me know. However I fear by the time I send it to you you will ave finished it! :smiling5:
                  Looking great so far. Keep up the good work. Are you going to try a desert colour or sticking with Panzergrau??
                    Hi Steve - So I assume that the front sprockets are wrong?!!!! I wouldn't know, and in my book, if it ain't broke......
                    I don't think I'll need any spares thanks - I'm trying my hardest to keep everything clean and unbroken. I might extend this one into a dio, with perhaps an armoured car.
                    I'm sticking with Panzergrau so that I can use the kit figures. They look paintable at least.
                    • Steve Jones
                      • 6615
                      They were only incorrect for the specific Ausf D I was building in the desert. Your generic one will be fine :thumb2:
                      • Lee Drennen
                        • 7711
                        I’ll be watching this Peter I was going to buy ones these I’ll see how you do
                        • Peter Gillson
                          • 2594
                          Hi Peter
                          Gosh, I remember building this kit back in the day. Seeing the inside of the hull takes me back - it looks like it was designed for their motorised version.
                          Peter
                            Steve - :thumb2:
                            Lee - If I can build it, anyone can.
                            Peter - Yes, designed to take a motor c.1975, then updated with a new sprue c.1977. The first Tamiya I made as a kid was a Tiger that included a motor - the thing worked too.
                            I watched the World at War episode on Barbarossa the other day and there was a lot of footage featuring Ausf Ds. This one looks near enough for me.
                            • SteveH
                              • 1287
                              Morning Peter
                              Great start, and definitely tank shaped, just like a Pz IV.
                              I have used brass rod through the back end to support weak idler wheel axles before now, especially with vinyl tracks.
                              I also built this one back in the 70's too, when it was the only game in town, and super for the 70's.
                              I think some of the Pz IV D issues might be by association, as the TriStar IV D had a real problem with hinges on the rear deck.
                              They copied the Achtung Panzer drawings which had the hinges on the wrong side!
                              Though a sharp blade and some glue, sorted.
                              The figures might be a step too far though, not that good from what I remember?
                              Have a good day building, not often I get to say that!
                              Regards
                              Steve H
