Dry brushing completed, installed radio antenna did a little highlighting on the tow cables and did a final wash on the tracks. When dry, I'll get a gloss coat on the turret for decals then seal with dull coat and do the final weathering.
Totally and I do mean totally amazing what you achieve in such a tiny kit. Your scratchy brings it to another level Buddy. I have been looking it over and the only negative point I've found is that the exhaust pipes on the rear deck are 5 degrees too far turned in. They should point more outwards…………………..
No way Rick, I have never seen a Russian vehicle that had straight slogans on it. I was going to ask what it meant as I thought it was "Death to the Facist Bambergers"...……..Still a fantastic build though!!!
