Dragon 1/35 German Super Tank Maus - or stitched up by my Grandson again!!
Thanks chaps.
Jakko - The Maus didn't have tracks fastened to the hull or turret sides, so I won't put stuff on it never had fitted. Apart from anything else, I've nearly completed one side of the tracks.
The Grandson is bound to check anyway, so I'll play safe.
Thanks for the suggestion none the less.
Cheers all.
RonComment
Are you building this as one of the vehicles that actually saw service, then, or as a might-have-been-had-it-entered-production? In the first case, I agree with you; in the second, it’s reasonable to assume it would have spare tracks on its turret or hull like other German tanks of the period.Comment
My goodness, just look at the time. I'm ready for a cup of cocoa.
Night night.....Comment
Well I hope you had your reigns on, and a tag with your name and address tied to your collar.... Mike.Comment
Jim, at least you got an ice cream for your troubles!
Update.
Nice to see the usual February weather back with us - Wet and cold. Although it does mean den time......:thumb2:
All wheel assemblies stuck to lower chassis.
[ATTACH=CONFIG]n1087434[/ATTACH]
I might yet fit the whole length of tracks. So just in case, I've fixed the top rollers in position. I'll make a final decision later in the build.
[ATTACH=CONFIG]n1087435[/ATTACH]
EDIT - I've had me a 'thunk' regarding leaving bits off this kit that are not seen. How could I even consider such a thing? It's my Grandson's model and his money! He entrusted it to me for heavens sake, so a full build it is..... :smiling4:
Mind you if it were mine I would be leaving loads out.
Cheers.
RonComment
Ron, after spending all that time building that suspension, it would be a crime not to go the whole hog and add all the tracks - go for it.... Mike.Comment
Good Crack!
Best part of today gone, but I've finished the suspension and tracks. It all went together without any major issues - Just a bit of a strain on the old peepers.
My 1/35 paratrooper gives a good indication just how big the tracks alone were on the brute. His rifle is touching the tracks.
Painting next. When my eyes return to their respective sockets, that is....... :flushed:
Cheers.
RonComment
