Academy 1/35 Warrior MCV
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4600
    • Bob
    • London
    Hi guys,
    Started on this the other day. Fairly simple kit so most of the building was completed in short order.
    Not a bad fit, bit of filler here and there. No flash but quite a lot of seams, and EPM's is some stupid places (like right in the middle of vision blocks).
    Comes with quite a few accessories for filling up the turret basket and hull bins, including (bizarrely) two folding chairs??
    Also included were two L85a2's which are very nicely moulded.
ID:	1087570Click image for larger version
ID:	1087571Click image for larger version
ID:	1087572Click image for larger version
ID:	1087573Click image for larger version
    Si vis pacem, para bellum.
  • Mickc1440
    • 4779
    this kit brought me back to modelling, nice work on yours Bob
    • scottie3158
      • 14201
      • Holbeach
      Bob looking very good, a nice selection of stowage. Is the turret basket broken is seems to be hanging down a touch in the rear view
        Bob,
        Fast work there. One suggestion is replace the plastic mesh in the turret basket if you can, ebay etc should be a source.
        Cheers, Mike.
        • Mr Bowcat
          SMF OG
          • Dec 2016
          • 4600
          • Bob
          • London
          Cheers gents.
          Paul, the mesh isn't fully glued in at the ends yet, and the basket does angle up at the bottom, but it's installed correctly. Maybe the angle the photos taken at?
          Mike, might look for some metal mesh for future builds as the nylon/plastic mesh than came with the kit was a pain. For this one I will live with it as there are several boxes and spools to be attached to the rear of the basket, and lots of goodies to go in it so the mesh will mostly be hidden.
            Did they correct the hull front add-on armour blocks? I built this kit when it was fairly new (so not the 2003 but the 1991 Gulf War version) and there were problems with the dimensions and/or fit of that bit.
            Those are somewhat common on modern AFVs, simply to give the crew somewhere to sit I suppose. Not sure of the British did this too, but you could cut a hole in the seat of one (or both) of them.
            That’s more praise than is usually applied to that rifle
              • 15702
              Hi Bob
              Looks nicely detailed and the "extras" are certainly worth having. Quick, clean build. Do you have plans to put it on a base?
              • Si Benson
                • 3572
                Nice build Bob:thumb2:
                • Mr Bowcat
                  SMF OG
                  • Dec 2016
                  • 4600
                  • Bob
                  • London
                  Cheers guys. :smiling3:
                  Jakko, the front armour went on ok. Needed some clamping while the glue dried, but no filler required.
                  Jim, eventually yes. I've previously built the Challenger and Bradley in desert colours, and I have an Abrams in the stash so might do a large base/Dio incorporating all 4.
                    • 15702
                    Now that would be worth seeing. Need a big shelf though! :rolling:
                    • col68
                      • 1505
                      Nice work Bob I built this last year and it's not a bad kit to build. To answer jakkos question about the frontal armour it is still wrong unfortunately.
                      • Mr Bowcat
                        SMF OG
                        • Dec 2016
                        • 4600
                        • Bob
                        • London
                        Cheers Colin.
                        • Jon Heptonstall
                          • 1704
                          Accurate armour do a resin replacement for the front armour package if it's an issue.
                          Jon.
                          • PaulTRose
                            • Jun 2013
                            • 6464
                            • Tattooine
                            this one ive always wanted to get.....i did the Bradley and really enjoyed it
                            Originally posted by Jakko
                            That’s more praise than is usually applied to that rifle :smiling3:
                            i must have been one of the lucky ones.......i got issued with a brand new one and the only times it let me down was when i did something wrong.........but then i looked after it
                            Per Ardua
                            • col68
                              • 1505
                              Must admit I never had a problem with L85a1 just hated having to clean it to many parts to loose
