Tamiya M20
  • scottie3158
    • 14243
    • Holbeach
    Tamiya M20
    My next build will is the M20 armoured utility vehicle. To go along with this I have the basic voyager etch set but not sure how much of it will get used.
    I want to have the front wheels turned slightly, but unfortunately the kit has fixed steering so a modification was in order. Legend models do an after market kit for steerable wheels, but I wanted to have a go my self. So the first thing was to remove the fixed hubs. then using a rotary ball burr was used to create a pocket then a small ball bearing was CA'd on to the ends. The pockets were created in the hub halves using the same burr. the halves were then glued together around the bearing allowing them to swivel. Then a new steering link was made from copper wire this was bent to shape then a flat was formed either end and a hole drilled through. A slot was created in the hub arms with a small razor saw and a hole drilled these were then pinned together. Finally the steering arm was added in the same way.
    It's not 100% correct but t does allow the steering to move when I have decided on the angle and direction I will glue it all up for strength.
    Hope to see you along for the ride.
    Scottie
    Hi Scottie, I can see another masterpiece on the horizon, nice start straighten with modification work like it, good luck with the rest of the build sir.
    Pete.
    • scottie3158
      • 14243
      • Holbeach
      Pete.
      Pete,
      Good to see you mate, hopefully it will go ok.
      • col68
        • 1505
        I'm grabbing a seat at the front for this one paul
          Right I'm in , next to Colin and Pete.
          Paul black coffee for me and if Si comes he might bring some cakes !
          Impressive work with bearings, and it turns ! Can see your ex REME . :smiling2:
          John .
          • grumpa
            • Jan 2015
            • 6142
            Nice work Paul, I would have just broke it and re-glued it into position.
            • Mr Bowcat
              • Dec 2016
              • 4625
              • Bob
              • London
              Looks good Paul.
              I'm with Jim, if in doubt hit it with a hammer. :tears-of-joy:
              Si vis pacem, para bellum.
                • 15799
                Hi Scottie
                Goody, goody - another foray into the crazy place that is "Scottie's Super Detailing World"
                First post and already great work. I think, like the others, I would have been tempted to have just cut off and glue the ends at an angle.
                I do hope Si does bring cake :tongue-out3:
                • minitnkr
                  • 7573
                  • Dayton, OH USA
                  Love it. Excellent silkpursery. PaulE
                  • BigGreg
                    • 2186
                    and it's gonna be AGAIN... something EPIC....
                    • yambam26
                      • Mar 2011
                      • 622
                      Well im in on this one, i would like a scale working differential please and sprung suspension!
                      Thought id best get the order in
                      • Steve Jones
                        • 6615
                        The master is back at it again! A wonderful improvement straight out of the blocks with the steering rod. Really looking forward to seeing this one come together. Good luck mate
                        • Mini Me
                          • Jun 2018
                          • 10711
                          This will be awesome! Will follow closely as I have a couple in the stash. Rick H.
                          • SimonT
                            • 2824
                            Excellent modding on the steering Scottie
                            Are the ball bearings fixed solid?
                            The only time I tried to glue ball bearings to something I found them so smooth that the glue would not grip - they just kept falling off and I abandoned the idea
                              Would you like to rewrite your comment - children are watching.....
