Tamiya M20
Paul, I notice you use Klear, giving a gloss finish to use the oils on, Steve in his post mentions mat varnish I've tried gloss and mat varnish , the pin washes flow slightly better of course with the gloss but not as fast as I've seen on videos on U tube . Is this gloss v mat just a personal choice ?
John .Comment
Its because he gets larger thick white envelopes from Klear. Whereas I only get small thin brown envelopes from Windsor Newton. Don't tell anyone as you may find a horses head in your bed tonite.
P.S I was bottle fed JD and coke from an early ageComment
You must have been very young to have started drinking then !:smiling4::smiling4::smiling3::smiling5:
John .
If I am the shorts wearing postman is intercepting them :tongue-out3:Comment
Unless you can see anything I have missed and I'm sure there is lots this is pretty much done. These will be the last pictures on here. If anybody wants anymore I will post some in finished armour.
Next I will be starting on the base so the next stage will be in dioramas under construction so hope to see you there.
Anyway enough of the waffle the wheels have been added, and the chassis and body weathered.
Many thanks for the very generous comments and support along the way.
ScottieComment
Afternoon Paul,
She turned out a real beauty and your work just gets better and better buddy!!! In the fourth pic, I think the stowage looks fantastic with the colors you used. The tarp roll looks especially realistic. If I could find a fault, it might be, depending on what time of the year, a little more dust on the accessories and/or in the corners. Then again, if it's in the Spring or Fall, disregard my bla bla....
Prost auf Dich
AllenLife's to short to be a sheep...Comment
Afternoon Paul,
Prost auf Dich
AllenComment
