1/35 HobbyBoss Sd.Kfz.254 Saurer
    This is going to be my next build............................Click image for larger version
Name:	hobby boss 254.jpg
    Rather unusual, which is what attracted me in the first place. I will put up some sprue shots, and some detail shots tomorrow, of some of the finest mouldings I've had in my hands. Vinyl tyres, a small PE fret. The construction, especially the suspension looks complex, and added to that, are individual track links - 138 per side.............
    Unusually, for a military armoured vehicle, it has no armament - two finish versions, one an Afrika Korps vehicle, in yellow, the other Panzer Grey.
    My pestilential Provost will be finished shortly, and the Beaufighter is in an advanced state, so construction will start later in the week
    Nice looking scout car Dave. Look forward to your next update and the build.
      Some sprue shots.......................Click image for larger version
ID:	1090414Click image for larger version
      4 of these:Click image for larger version
      2 of theseClick image for larger version
      And lots of theseClick image for larger version
      Decals/PE/TyresClick image for larger version
      Ans some detail shots...............Click image for larger version
      Those tracks...............Click image for larger version
      Some very fine moulding - serious care will be needed to detach these from the sprue - Click image for larger version
ID:	1090416Click image for larger version
      Some really nice single piece moulding!Click image for larger version
      And, when you look at this closely - super detail - the bolts through the chassis flange!Click image for larger version
      I've looked carefully, no injector pin marks in visible positions, and no flash. Some of the ingates are a little large, but nothing that a new 10A blade can't cope with!
      I must say the mouldings are really good, it remains to see whether the fit comes up to the same standards!
      • minitnkr
        • 7576
        • Dayton, OH USA
        Nice choice. Sprue shoots look good. Those tires are very well done. The basic shape is effective, but the track/wheel engineering looks vulnerable. PaulE
          Paul,
          considering the 254 weighed in at over 6.5 tonnes, the wheels look very small, and anaemic!
            Dave this looks to be a nice kit. Nice detailing and the sprues look crisp and clean.
              • 15817
              Hi Dave
              That looks a nice kit of an unusual subject. The tracks will certainly test your patience.
                Tip: carefully saw through the connections rather than use snippers or a knife.
                  Waiting for weathering to dry on my Beaufighter, construction started on the 254 - suspension bogies.................Click image for larger version
                  You have to be careful when removing the parts from the sprues, it's easy to cut off tiny locating pins!! Careful study of the instructions is vital.
                  The main chassis and body - part assembled/dry fittedClick image for larger version
                  Not very long - but the height seems to indicate that this thing was top-heavy! I have read reviews, indicating that there are fit problems - but either HB altered the mouldings, I'm lucky, or the reviewer had a bad day............
                    Dave .
                    When I cut the parts there is always that gap under so I've decided to put some hard foam under the sprue so when I attempt to remove the links they don't get bent and snap I've had this happen to many times.
                      John,
                      I often cut the sprue up, to remove any projections - this should allow you to get the back of the part supported by the cutting mat.................
                        Further work on the suspension - at least the tracked part!Click image for larger version
ID:	1090707Click image for larger version
ID:	1090708Click image for larger version
                        There are some tiny PE parts (9) I have missed out..........................Click image for larger version
                        These are grease nipples for some of the bearings - I'll wait and see if any of them will be visible after assembly, before deciding not to fit them!
                          Itโ€™ll be easier to make those with a punch and die set than to clean up and add those etched ones, Iโ€™d think.
                            Thanks Dave , handy tip .
                            Looking very clean, I'm for the tracks !
                            John.
                              I've dry fitted the sprockets & idlers, so I can measure some track lengthsClick image for larger version
                              I spent part of last night removing some of the tracks...............................
                              Just a simple matter of joining them up!
