SimonT - Tamiya T34/76
  • minitnkr
    Charter Rabble member
    • 7551
    • Dayton, OH USA
    #46
    John Wick 3. :smiling2: PaulE
    • JR
      • May 2015
      • 18273
      #47
      Apart from breaking bits off it still looks good Simon.Of course a T34 all ways looks good:smiling3:
      • SimonT
        • 2824
        #48
        Mike - I rather enjoy reworking these old T34 based kits
        Richard - cheers
        Paul - I rather like John Wick. 3 does go a bit weird though
        John - agreed. The broken hubs are annoying but should be easy enough to fix - I made them before so can make them again
        Finished off the left track last night
        Rather annoyingly as I was adding the last run of links on the top I found that I was 3/4 of a link short of joining the links already installed on the drive sprocket
        With no adjustment available in the wheels I had to bodge it a bit
        by flooding one of the joints on the bottom run near the back end I managed to separate the track
        I could then turn the sprocket to enable the track to join to the main top run
        on the bottom run I shaved down two links to 3/4 width and inserted in the gap - doesn't look too noticeable and a bit of mud should hide things nicely
        I now have a removable wheel/track combo
        For the right side, knowing now that there is a chance of them not fitting, I shall start with the top run so the adjustment point, if required, will be on the bottom run hidden by a wheel
          • 15737
          Morning Simon
          Track looks fine - quite a result. Having wheels with fixed track removeable is a great idea. Surprised we don't see it more often. Common on small scales.
          Isn't hindsight a wonderful thing :smiling2:
          Stay safe.
          • SimonT
            • 2824
            #50
            Yes Jim, unfortunately my memory is not so good - I’d forgotten that I had already assembled the bottom run last time I worked on it :rolling:
            • minitnkr
              • 7551
              • Dayton, OH USA
              #51
              Yes, a good character for him. I enjoyed them all. 3 was quite an excersize in choreography, but it & 2 didn't measure up to 1 storywise IMHO. You may like Collateral (Tom Cruise) & The Accountant (Ben Affleck), both have good stunt work & are quite diversionary while "lapmodeling".
              • SimonT
                • 2824
                #52
                Seen Collateral, not seen The Accountant so will keep an eye out for that one Paul :thumb2:
                finished off the right side track
                worked towards the front and managed to adjust the idler slightly such that i didn't end up with an odd sized gap this time
                slight problem now - i have been unable to locate the box of remaining bits for this one
                had a bit of a tidy around at christmas to make things habitable for when my sis visited so lots of part built kits got shoved out of the way
                they are obviously here, somewhere, i just can't remember where i stuffed them out of the way - whoops :thinking:
                • minitnkr
                  • 7551
                  • Dayton, OH USA
                  #53
                  Been there, done that, got the T-shirt & the sound track. Usually found during next biyearly tidy. PaulE
                  • SimonT
                    • 2824
                    #54
                    Luckily Paul I eventually found the correct box :thumb2:
ID:	1122911Click image for larger version
                    the track units dried overnight to leave them nice and solid
                    replaced the missing centre caps that I had knocked off then made some new hubs for the idler wheels - these replace the soft vinyl things that are supplied in the kit (a throwback from when this was a motorised kit)
                    I also added the single headlight on the left hull side, some spare track links on the track guards, a tow cable and the radio aerial mount on the right hull
                    Forgot to take pictures of all of them though - in my defence it was 2am and I had just woken up in front of the telly again :rolling:
                    Not too much more to add to this one before I can start throwing paint around
                    • SimonT
                      • 2824
                      #55
                      I was just mounting up the parts ready for spraying when I realised that I had forgotten to add the bolt heads to the engine cover grille surround
                      so, 54No. 0.5mm bolt heads later I had this
                      I think that now finishes it off and makes it ready for some paint
                      Here are the bits I forgot to take pics of previously
                      headlight and horn assembly with lead wire conduit added
                      some spare track links added to the track guards
                      stub axles masked up ready for paint
                      tow cable from twisted wire fitted to the kit ends after removal of the kit plastic cable
                      radio aerial added from music wire and guitar string spring
                      mg barrel from brass micro tube
                      next stop, paint............
                      • SimonT
                        • 2824
                        #56
ID:	1123030Click image for larger version
ID:	1123031Click image for larger version
ID:	1123032Click image for larger version
                        up early(ish) and got some One Shot primer on
                        • scottie3158
                          • 14216
                          • Holbeach
                          #57
                          Simon,
                          Excellent as always mate.
                            • 15737
                            Hi Simon
                            Always nice to get a coat of primer on. Hope it hasn't shown up any areas needing work.
                            • Steve Jones
                              • 6615
                              #59
                              Its always the last bits of detailing that takes the longest. Nice to see the wet stuff out. Have you ever left a build as is with no paint on?? Intentionally of course - not one of your many shelf queens :smiling2:
                              • SimonT
                                • 2824
                                #60
                                Cheers Scottie
                                Jim - not seen anything yet, but you never know....
                                Steve - not intentionally no. Painted finished model is the logical conclusion whether scratched or kit
                                After finishing work for the day I got the 4BO out and wafted it around
                                pictures later
