SimonT - Tamiya T34/76
  • scottie3158
    • 14216
    • Holbeach
    #121
    Simon,
    Who's a mucky pup then. Nice work.
    • SimonT
      • 2824
      #122
      John - no longer a problem as picked them off with tweezers :thumb2:
      Steve / Scotty - who doesn't like throwing mud around :smiling5:
      Started looking at the crew - they were not as good as I first thought
      The driver will hardly be seen so I am going to use the kit one but the two up top are getting a re-work
      First task, off with their heads
      arggh - gone fuzzy again. Looks like it decided to focus nicely on my jeans instead :rolling:
      Basically I sliced off the belt and cross belt and filed grooves where they had been
      Cut off the collar detail so that I could sit the cross belt below the new collar
      Drilled out the neck to take a Hornet head
      Made new belt and cross belt from micro-strip then added Historex buckles
      New collar made from Duro
      Sharpened up all the creases
      Separated fingers on left hand then sliced hand off arm so it could be rotated slightly to give a better position on the turret hatch
      Hollowed the end of the right sleeve
      Flare pistol will get barrel drilled out
      this is roughly how he will be positioned in the turret
      same treatment for the second chap but still to be finished
      rear view of them both
      • Mini Me
        • Jun 2018
        • 10711
        #123
        Those will do very nicely Mr. T. You think the kit heads were bad on your model, you should see what I have to put up with in my scale. The heads are way too big and the poses are rigid. With their tanker helmets on they remind me of Mr. Potato head.:sad: Roco have done us dirty! Cheers Mate, Rick H.
        • SimonT
          • 2824
          #124
          Preiser do some very nice figures though if you can get hold of them
          • SimonT
            • 2824
            #125
ID:	1125108Click image for larger version
            had to chop off the left hand of the bloke on the right and reposition it to get a better fit with the hatch
            separated his fingers whilst I was at it
            so that is the basic poses set just need to tidy them up now
            • Steve Jones
              • 6615
              #126
              Nice alterations on the figures Mr T. I'm sure you are looking forward to painting them.
              • SimonT
                • 2824
                #127
                A little more work needed with the putty before painting can commence Steve
                I have the brushes, paint sets, how to books etc, just lacking the bucketful of talent to make a good job of them - another area that I need to practice
                I am happy with the progress on painting of the tank so you never know, maybe I will be able to come up with something of passable quality on these two with a bit of luck
                • SimonT
                  • 2824
                  #128
                  feel free to laugh - I know they look like they are in sleeping bags but they are not a serious attempt at sculpting
                  I just needed some bulk to fill the turret and give the impression that they are not really only half the men they used to be
                  Tamiya has cruelly cut them off in their prime such that when inserted in the turret it is a bit obvious that they are truncated
                  this makes it look like there is a lower torso but without wasting hours on sculpting that will not be seen
                  • rtfoe
                    • 9099
                    #129
                    Ah, Simon, the mermen look good with new heads. Also good handholds for painting.
