1/76 Cromwell cruiser IV tank build.
    Hi well I have just started my first ever kit build, The Cromwell IV tank. Everything seems to be going together nicely. A few pieces to clean but I’m happy with my progress.
    I will leave the suspension and wheels to fit till last as advised. Some pictures.
    Have fun :smiling3:.
      Thanks SWR, I am having fun. Can’t believe how small they are and the detailing is quite good to.
      • stillp
        • 8094
        • Pete
        • Rugby
        Looks good! Also, if you're having fun, that's all that matters.
          Thanks Pete a little fiddly but worth it as it develops.:smiling3:
            Some more progress made today. The turret has been built and primer applied. The sides of the hull have been painted to accommodate the wheels and track. These will be weathered at a later date.
            Skirts have been fitted but very fiddly. All in all I’m pleased with my first ever build.
              Hi I thought I would take a picture of the turret painted up. Primer was applied first. Then followed by the first base coat which looked horrible. Gave this time to dry then applied a second coat and noticed a big difference. Again allowed this to dry and a applied a third coat and it looks lovely.
              Will paint the smaller details when fully dried.
                • 15707
                Hi Kevin
                And so you should be. You're doing a great job. Definitely right in that multiple thin coats of paint are the way to go.
                Keep having fun!
                  Originally posted by Jim R
                  Hi Kevin
                  Keep having fun!
                  Jim thanks for the nice comments. It means I’m going in the right direction. The main tank has had a coat of primer and a first base coat, this will need to dry properly before applying another coat.
                  My next build will be in 1/35 scale.
                    • 18271
                    Hi Kevin. You build looks good.
                    On a side I note you are posting questions directly related to this build in sections around the forum, as your a newcomer I thought I would point out that you can ask in the build thread as you go. People following will help where they can.
                    It makes for a more interactive thread, and for your own good, the replies are all one place so you can find them.
                    This applies to all by the way.
                      Hi I have finally finished painting the base coat on my Cromwell tank. My brushing technique has turned out well.
                      Gloss varnish will be applied tomorrow to allow for pin washing detail and weathering, then followed up with some Matt varnish.
                        Hi Ian I will remember this in future builds. As it does make sense to keep everything in one place. :thumb2:
                          Looking good Kevin.
                            Thanks SWR for the positive comments. :thumb2:
                              Kevin,
                              That is a great start for your first ever kit build, and as you say you are having fun and that is the main thing to remember.
                              Cheers, Mike.
