Chieftain Mk5 (Tamiya 1/35)
    Hi got the Horstmann suspension units, sprocket, idler, road wheels and skirting plates bracket all made up and fitted.
    Drilled out road wheel drain holes.
    Drilled out hub caps drain holes you can also see the road wheel drain holes .
    Thank you for stopping by and all the parts did come OOB .
    Pete.
      I'm watching.
        • 22771
        #18
        Great start Pete.
          Originally posted by SWR
          I'm watching.
          Hi Ralph not much to see yet waiting on PE set to come but you are more than welcome then I can get going.
          Hope you are well.
          Pete.
            Originally posted by papa 695
            Great start Pete.
            Cheers Ian, thought I better do a bit.
            Pete.
              Pete,
              You are cracking on there. Are you going to blank off the underside holes and especially the one behind the drive sprocket which can be visible frome the rear quarters.
              Cheers, Mike.
              • Steve Jones
                • 6615
                #22
                I could have sworn I posted on this build already. Really enjoy seeing you update kits the way you do. Wonderful detail and research going on already. Hopefully the PE kit turns up soon. Keep up the great work. Taking notes as we speak :thumb2::smiling3:
                • SimonT
                  • 2824
                  #23
                  Off to a good start
                  I got the Eduard set as well - three frets with a lot of very small looking bits :surprised:
                    Originally posted by MikeC
                    Pete,
                    Cheers Mike glad you popped in to keep a eye on my someone got to, yes I have made the blanks for the sides and floor but haven't fitted them yet.
                    Any more tips / information will always be greatfully received.
                    Pete.
                    Hi Mik
                      Hi Steve I do the same all the time, I hope you find it enjoyable watch but your only need a small note book, I lean more looking at your work than your ever lean from mine.
                      Pete.
                        Originally posted by SimonT
                        Off to a good start
                        Hi Simon and thanks, I've seen the three frets and your not joking about being small.
                        Will still have a go at fitting them.
                        Pete.
                          Hi Pete,
                          Not a problem with the etch, just replace what you think needs replacing, nick the wifes flat eyebrow tweezers as your holding device, and then deny all knowledge of seeing them. Wife now looks like a Wookie...
                          Just off to hide.... Cheers, Mike.
                            Hi biuld is on hold can't upload pic's just one more thing that's gone wrong since I've rejoined.
                            • scottie3158
                              • 14227
                              • Holbeach
                              #29
                              Pete,
                              Just found this mate, count me in I'm just squeezing my way to the front.
                                Pete,
                                Hi Paul sorry to say I've stopped this build can't upload a thing.
                                What's the SMF support all about have you been promoted.
                                Pete.
